1994 R32 GTR, the car's had blitz blow off's going to atmo for a while, gone to reinstall the stock blow off, removed the blanking cap from the pipe to have a fair amount of oil come out, what's this mean? a blown turbo oil seal prehaps? pic of the pipe i'm talking about below.
view through the front bumper
with the bumper removed
the blitz blow off valves.
You found oil in the dead end of the recirc line? That's the lowest point, I suppose it could find its way there whilst it was blocked off at the BOV end if it was still connected at the turbo inlet end, but it could be residual from when the recirc BOVs were still being used. What's a "fair amount" of oil? 1 tablespoon? A cupful?
There's always some oil in the intercooler plumbing - the cam cover breathers also connect into the turbo inlet and depending on how much your engine breathes, you'll have anything from a little to a lot of oil in there somewhere. A lot of oil is of course undesirable - for one it tends to suggest a lot of breathing which is a sign of wear, and it also tends to promote detonation because engine oil being breathed in with the air-fuel mix has a low detonation threshold.
Oil can of course enter the induction tract from leaky turbo seals. It can be hard to work out where it's coming from though.
If you've got enough oil being breathed in to cause you running problems, then you'd probably notice a reasonable amount of oil usage across a service interval.
called previous owner, he say's he's been running the blitz BOV for around a year which would explain the build up of oil, no air flow through the pipe meaning no way to get rid of it, also explains the oil leak onto the front bumper, reinstalled the stock blow off valves and plumbed them back in, solved my over fueling issue and leaking oil issue, oil's green because the previous owner used martini oil's, which are green.
Edited by ttoks
If you want to do the right thing by your car, you need to pull off the intercooler, return pipe and all the intake hoses and give them a good clean.
Flush the intercooler with petrol until you can shake about 200ml of petrol in there and have it poor out clean. Same with the return pipe.
Most important of all, invest in a catch can that actually works or you will be cleaning it all again in a few months.
Best cleaning methond is a 50/50% mix of Methylated Spirits & Kerosene.
:thumbsup:
Please tell me you had the motor and car properly inspected before purchase?
Just cleaning the pipes would be the end point. For safety sake get a comp/leak down test done.
Especially given the price it was selling at - perhaps you've just found the reason why it was cheap.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
