1994 R32 GTR, the car's had blitz blow off's going to atmo for a while, gone to reinstall the stock blow off, removed the blanking cap from the pipe to have a fair amount of oil come out, what's this mean? a blown turbo oil seal prehaps? pic of the pipe i'm talking about below.
view through the front bumper
with the bumper removed
the blitz blow off valves.
You found oil in the dead end of the recirc line? That's the lowest point, I suppose it could find its way there whilst it was blocked off at the BOV end if it was still connected at the turbo inlet end, but it could be residual from when the recirc BOVs were still being used. What's a "fair amount" of oil? 1 tablespoon? A cupful?
There's always some oil in the intercooler plumbing - the cam cover breathers also connect into the turbo inlet and depending on how much your engine breathes, you'll have anything from a little to a lot of oil in there somewhere. A lot of oil is of course undesirable - for one it tends to suggest a lot of breathing which is a sign of wear, and it also tends to promote detonation because engine oil being breathed in with the air-fuel mix has a low detonation threshold.
Oil can of course enter the induction tract from leaky turbo seals. It can be hard to work out where it's coming from though.
If you've got enough oil being breathed in to cause you running problems, then you'd probably notice a reasonable amount of oil usage across a service interval.
called previous owner, he say's he's been running the blitz BOV for around a year which would explain the build up of oil, no air flow through the pipe meaning no way to get rid of it, also explains the oil leak onto the front bumper, reinstalled the stock blow off valves and plumbed them back in, solved my over fueling issue and leaking oil issue, oil's green because the previous owner used martini oil's, which are green.
Edited by ttoks
If you want to do the right thing by your car, you need to pull off the intercooler, return pipe and all the intake hoses and give them a good clean.
Flush the intercooler with petrol until you can shake about 200ml of petrol in there and have it poor out clean. Same with the return pipe.
Most important of all, invest in a catch can that actually works or you will be cleaning it all again in a few months.
Best cleaning methond is a 50/50% mix of Methylated Spirits & Kerosene.
:thumbsup:
Please tell me you had the motor and car properly inspected before purchase?
Just cleaning the pipes would be the end point. For safety sake get a comp/leak down test done.
Especially given the price it was selling at - perhaps you've just found the reason why it was cheap.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
