so guys i was just here too ask one question
how many kilometres on average do you get out of your n/a skyline
im only getting around 350kms out of a tanks and i dont drive around high rpm so i was just wondering mainly too see if i got a problem or not because that really is not good fuel economy
and im not complaining i wouldnt switch my r33 for anything in the world but just curios is all
If this is in the wrong spot just delete it please.
https://www.sau.com.au/forums/topic/380292-fuel-consumption-in-a-na-skyline/
  • Replies 72
That sounds about right for an R33 GTS .. GTS-4 are a bit worst I believe, having potenital AWD + being heavier.
When I had my NA R31, I got about 450 to a tank (400 if I drove spiritedly).
I now have an EF XR6 5 Speed and I got about 650km / tank / normal driving & about 1000km / tank highway driving (quite amazing for the car it is).
This is all using regular 91 unleaded. When I used premium in the 31 I got maybe an extra day or two worth of driving out of it, in the falcon it doesnt make much difference at all.
When I first got the 31, it had heinous economy, however I replaced the oxygen sensor & sparkplugs and it got alot better.
yep its a r33 with all the parts on it from factory so they are not performing like they used to. People with turbo's usally have more knowledge and money than people with non-turbo's, note the engine bay :) . Thats why there car can get more fuel, its in better condition.
I get 500km to a full tank around normal roads (no highway driving included) using highways about 600km, GTS-4 and its 2.7L now.
I used to get 300km to a full tank but i brought brand new-
Fuel pump
All the Filters
Oils
AAC Valve
Cold start Valve
Coolant temp sensor
TPS
Rebuilt Engine
Engine Gasket Set
O2 sensor
Plugs
seems to have fixed it.
Edited by central coast person
its probably not that far out depending on how easy your driving it, even with a power fc and gentle driving i get approx 450 out of a tank, but usually can only get bout 50L into it even on the empty line, so that doesnt sound so bad i guess, maybe your just doing alot of city driving and bit heavy on the throttle plus bit low on compression and tune etc
+1 to the falcon, i drive one daily and it is just superior for doing the km's, 10L/100kms it is just pure torque, its an auto and 1700rpm just gear changes flowing and keeps up with traffic, easy and economical what more can you ask for? handles like a boat but thats not what its being used for lol..
:whistling: 800kms from 75L in a 1700kg twin turbo whale.
Its all about how you drive them
you have a gtt-L?
they're about 1600kgs or less though, 1jz ones. boosting around i get about 500-600km till the the thing starts to surge under boost. i did about 800kms on one tank when i was driving the thing back from shitney.
you have a gtt-L?
Its pretty much the L-package...has all the options except leather
Prob weighs 1650 less driver
I hated that surge with less than 10L in the tank...fixed it with a new pump though, can go WOT with 5L and no surge
i have an L pack too, just that, dickhead of the previous owner, put in an aftermarket steering wheel and boss kit, and cut off the wires for the cruise control and stuff. so, i lost some awesome features.
pray tell, what pump did you put in? new toyota pump? or an intank bosch?
nah. s1.
if it didn't have cruise control, it wouldn't have the A/D light coming on right?
i'll have to go hunt for a bosch 910, i'm sick and tired of that surge, and also the L pack's fuel sender is the shittiest thing ever invented. only has a vague idea of how much fuel i have left. so i wait till it surges. lol. so, i'm not sure if i want the surge or not.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
