so guys i was just here too ask one question
how many kilometres on average do you get out of your n/a skyline
im only getting around 350kms out of a tanks and i dont drive around high rpm so i was just wondering mainly too see if i got a problem or not because that really is not good fuel economy
and im not complaining i wouldnt switch my r33 for anything in the world but just curios is all
If this is in the wrong spot just delete it please.
https://www.sau.com.au/forums/topic/380292-fuel-consumption-in-a-na-skyline/
  • Replies 72
That sounds about right for an R33 GTS .. GTS-4 are a bit worst I believe, having potenital AWD + being heavier.
When I had my NA R31, I got about 450 to a tank (400 if I drove spiritedly).
I now have an EF XR6 5 Speed and I got about 650km / tank / normal driving & about 1000km / tank highway driving (quite amazing for the car it is).
This is all using regular 91 unleaded. When I used premium in the 31 I got maybe an extra day or two worth of driving out of it, in the falcon it doesnt make much difference at all.
When I first got the 31, it had heinous economy, however I replaced the oxygen sensor & sparkplugs and it got alot better.
yep its a r33 with all the parts on it from factory so they are not performing like they used to. People with turbo's usally have more knowledge and money than people with non-turbo's, note the engine bay :) . Thats why there car can get more fuel, its in better condition.
I get 500km to a full tank around normal roads (no highway driving included) using highways about 600km, GTS-4 and its 2.7L now.
I used to get 300km to a full tank but i brought brand new-
Fuel pump
All the Filters
Oils
AAC Valve
Cold start Valve
Coolant temp sensor
TPS
Rebuilt Engine
Engine Gasket Set
O2 sensor
Plugs
seems to have fixed it.
Edited by central coast person
its probably not that far out depending on how easy your driving it, even with a power fc and gentle driving i get approx 450 out of a tank, but usually can only get bout 50L into it even on the empty line, so that doesnt sound so bad i guess, maybe your just doing alot of city driving and bit heavy on the throttle plus bit low on compression and tune etc
+1 to the falcon, i drive one daily and it is just superior for doing the km's, 10L/100kms it is just pure torque, its an auto and 1700rpm just gear changes flowing and keeps up with traffic, easy and economical what more can you ask for? handles like a boat but thats not what its being used for lol..
:whistling: 800kms from 75L in a 1700kg twin turbo whale.
Its all about how you drive them
you have a gtt-L?
they're about 1600kgs or less though, 1jz ones. boosting around i get about 500-600km till the the thing starts to surge under boost. i did about 800kms on one tank when i was driving the thing back from shitney.
you have a gtt-L?
Its pretty much the L-package...has all the options except leather
Prob weighs 1650 less driver
I hated that surge with less than 10L in the tank...fixed it with a new pump though, can go WOT with 5L and no surge
i have an L pack too, just that, dickhead of the previous owner, put in an aftermarket steering wheel and boss kit, and cut off the wires for the cruise control and stuff. so, i lost some awesome features.
pray tell, what pump did you put in? new toyota pump? or an intank bosch?
nah. s1.
if it didn't have cruise control, it wouldn't have the A/D light coming on right?
i'll have to go hunt for a bosch 910, i'm sick and tired of that surge, and also the L pack's fuel sender is the shittiest thing ever invented. only has a vague idea of how much fuel i have left. so i wait till it surges. lol. so, i'm not sure if i want the surge or not.
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
