Wow way to get shot down for asking a f**king question
Maybe some could explain WHY it's such a bad idea to run this fuel, it's cheap as hell i'm sure people are tempted to use it
Edited by brat81
  • Replies 72
do you mean E10?
my guess is yes
ok, i'll give you a somewhat more in depth answer, albeit in point form
- ethanol has a different stoichmetric value (the ideal air/fuel ratio) so you need to run a much richer AFR
- ethanol makes a smaller bang because it burns colder so without a tune you will make much less power
- once the tuned is richened up then you will make similar power
- corrosive properties as mention, however not as bad as some people make out.
- fuel economy is much worse than regular fuel (as mentioned, you need to run it much richer) to the tune of about 30% which negates the lower price
  • 5 months later...
jjman could you please give me a link to business traders on here for o2 sensor would be great
im not going to do the search for you but they are pretty easy to find in the business traders section.
Just go into that section and then in the search window type in O2.
  • 2 months later...
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
