Is the air temp sensor part of the AFM on R32? Those of you with RB20DET running on PFC... Do you get an air temp reading on FCC?
I cant remember if I had a reading last night or not... But I dont have one now!
Regards
https://www.sau.com.au/forums/topic/38031-air-temp-sensor-rb20det/
I dont think... can hook up though, just mirror wiring as per RB26DETT.
I am only a novice on these PFC's and have had to work it out myself. They certainly aren't space shuttle stuff by any stretch
TT
  • 6 months later...
SK for your 26/30 using GTST PFC , can it use the GTR's air temp sensor ?
Not sure what you mean by "use", I can plug the standard GTR air temp sensor into the Power FC, just add a wire to GTST ECU plug using the standard GTR pin number. The R32 GTST Power FC does have a 3 stage air temp correction table coupled with the 2 stage boost correction table for fuel. It also has a 3 stage air temp correction table for ignition which is independant to the 2 stage boost correction table for ignition. This gives a pretty wide range of corrections for both fuel and ignition that can be separately referenced to inlet air temp.
This is accessed via the Datalogit software, I don't think the Commander has access to this area.
Hope that helps
SK - did you use a proper GTR temp sensor, or is there a generic item that is available?
Very interesting thread, as at the moment I am running a temp sensor from Jaycar, that has a thermocouple that sticks into my intercooler piping
Would this work the same for R33 PFC as well?
thats my spin...
Chris, I am just going to do as Skid said.... Actually robbed a redundant A/C spade out of my mates ECU plug today.
All I need to know is, Does the BNR32 sense in the air box? (doubt it) Or in the positive duct after the intercooler... (Would make sense to me)
TT
sorry to go off topic a bit...
hmm as far as i am aware RB25DET doesn't have a air temp sensor, am i right? or is it in the AFM?
my cars never had one anyway as the loom to the microtech is still like new (never been cut or soldered). a mate has given me a sensor of his series 4 RX7 and said give it a go.
wheres the best place to locate this? before the TB or after in the plenum?
The air temp sensor out of the series 4 wont work unless the microtech has been calibrated for it in the factory. I actually had this problem on a series 4 where the stock sensor was still being used with the microtech and it read from well into the negatives up to about 10-15 positive which equated to about 80 degrees i discovered when i got the correct sensor.
The default setting is for an AC Delco sensor that you can pick up for peanuts at you local holden dealer or auto electrician but is about 5 times bigger than the s4 one :wave:
  • 2 months later...
I have tried a few Nissan places in Adelaide today for the std GTR air temp sensor, no go:(
Does anyone know a Nissan dealer in Adelaide or Melbourne that stocks import / GTR parts? Im hoping to get it before the weekend so i can wire it up to my APEX Engineering PFc on my RB20, since im installing a new loom and all:)
  • 3 years later...
i now this is an old thread hahaha...
but im running a rb26dett pfc in my 20...
now i need to swap my air temp sensor with a vl commy water temp sensor as im getting bad economy due to my cold start settings...
how do i swap them? were are they?
cheers
AIR temp and WATER temp are 2 totally different things. RB20 uses the hot wire in the AFM as an indicator of air temp. RB26 has a dedicated air temp sensor, located in the inlet plenum just behind the throttle body.
Cold start should not have that big an impact on fuel economy, unless the engine always runs cold.
This does not work
under ETC, SENSOR SW CHECK do you see a sensor called AIRT?
if you do, it will work as the PFC you are using has that sensor active and ready
if you don't then the PFC you are using doesn't support airtemp
hooking up a sensor to any wire will achieve zero (in fact it puts the PFC at electrical shock risk)
so if you have AIRT go for it, if you dont, dont bother
R32 PFC does not have AIRT, same as R33 as R32 PFC is remapped R33 PFC with VCT removed, map changes and injector changes
if you want the correct part # for the GTR air temp sensor open up nissan fast, load in an RB26 VIN
then goto the view of the plenum and intake , and youll see the GTR air temp sensor just in front of the throttle body
its the same physical part as the water temp sensor, just with a J on the end of the part #
well if your water temp is 80deg and your air temp is 80deg id say its summer outside or your compressor working hard
do you have a proper air temp sensor installed? where is it? what does ETC, SENSOR SW CHECK show for AIRT at idle?
hahaha.... i dont know were the air temp sensor is.. i dont know wat etc is and i dont know wat airt is at idle!
im trying to fix a problem i dont know anyting about.. sorry for my dumbness but thankyou for ur help
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
