Does anyone know somewhere that makes seat rails?
Would the BRIDE ones fit on a Sparco Evo 2 seat?
Also the seat needs to be kept low, the stock seat rails are really really low. So it would be good to keep it that way!
Let's talk the same language here.
The seat itself sits on a rail that slides back and forth.
This rail then bolts onto a frame that has eyes for the bolts that go into your floor.
The rails are general easily available in reasonably generic form (ie. from say Revolution Racegear).
The frame that is custom to the R32/33/34 (same IIRC) is harder to get.
T.
me and a mate made some, still need some finishing though but are pretty good! totally fixed dont slide, but who needs that if setup right in the beginning. they are illegal anyway unless the fold forward! just used 0.8mm flat bar and welded it up! can post pics if you need ideas!
Sparco have something like rails for something like 1,000 different model cars. I contacted an American website regarding the Evo 2 who said "Their are no left-hand drive Sparco seat rails for R33's available, only right-hand drive" (He must have thought I was an American).
Does the Evo2 have sidemounts as well as floor mounts or just floor mounts? I can't actually remember....
Try calling the Australian Sparco Distributor (??).
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
