R33 Intake, What Fuel Rail (R32/33/34) Gives The Most Injector Options?
  • Replies 48
so do you guys have experience using that deatschwerks injectors? prices look good
just got my motor going again with some 1000cc side feed deatschwerks. had a little trouble with the latency but all sorted now and idle just as well as the nismo 555s they replaced. can drive around at low revs and idle like a stocker with enough fuel capacity for 800+hp
The 740s are only $50 more than the 550s, there is no reason to not get them is there? Only aiming for 250kw, maybe 300 in the future but I see 250 being plenty for quite some time.
Edited by Rolls
Hi Rolls i just did the injectors on my 34 gtt with stock rail and there are so many options.
Bosch ev14 injectors come in many sizes.
Sard
Nismo
Deatchwerks
Seimens
List goes on
All the ones i listed are bolt in. You dont need spacers or adaptor.
The only change needed is the plugs are different.
The bosch EV14 injectors come in sizes up to ID 1000 cc
You need to buy the 3/4 injectors for a neo. I just put them in my 34 with stock rail stock intake.
I paid 550ish for injectors 180ish to install and under half a hour to tune.
Plus RB20's use side feed injectors neo's use top feed
Edited by whitneybra
Rolls im in the same boat as you, im also looking for injectors that are regency friendly with the stock fuel rail, either going to go nismo or deatchwerks, im pretty sure the deatchwerks are just a highflowed stock injector? if anyone can confirm...so should be same colour etc.
Sard
Nismo
Deatchwerks
Seimens
List goes on
Nismo only come in 480cc which is too small imo, especially if you ever want to run E85.
The destschwerks are the only option that are truly direct fit. The rest require some form of modification to work.
Yeah going to buy the 740s, not cheap but I want to pass and want room to move in the future if I want to try E85 or aim for 280kw
Thanks for the help everyone!
Edited by Rolls
where are you purchasing them from mate?
Thanks everyone for correcting me about the rb20 injectors
www.tuffcarparts.com shoot these guys a email they sell lots and there was even a group buy here on SAU
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
