Hi people
Quick query this one –
Will a R33 GTR clutch fit an R33 GTS-t? I am under the impression that one is push and the other is pull type…?
It it does not fit directly, can the GTS-t be converted easily (and cheaply) enough to convert to fit the GTR clutch?
Cheers all
GTST is push GTR is pull. At the least you would have to get the GTR slave cylinder and rod and the GTR clutch activating lever ect. the clutch pressure plate is quite different. You would be far better off with aftermarket GTST clutch.
