  • Replies 150
mix of both cars
I made the mistake of looking at the dates of these... been so long since I drove in anger on a track its depressing
You do know there is a very easy way to fix such a problem?
Yeah that's why pretty much all of my Targa pics have watermarks - always been too tight to fork out the $400 on pics! :)
Here's some others of my car(s) I've found laying around.
And a good one of the last girl before the suspension was sorted!
I've always wondered..... what does the number plate signify?
You are so uncultured :)
It's the name of the dragon out of Tolkien's novel "The Hobbit" - because the old girl was also a fire breathing, money hoarding monster. :)
Mmmmmkay
Gotta agree Zebra, love the name and the reference (knew it was familar) but the non geek reply had me on the floor with laughter, rare so soon after waking up! Thanks guys, also that shot of the 34 bottoming out...ouch. So painful to watch, surely it was a nightmare inside the car?
was that with stock suspension or just way too low?
love the car and good to see a 34 used in anger, absolute dream car for me and the more Tolkien references you can fit on one the better!
:worship:
Mt stuart rally sprint/V8 track
Cardwell Rally
Didnt end so good though.....flat and back anyone!
Everyone likes the flames
Back when I use to race/drift/motokhana my old daily driver
Sunday Beach drive :)
Edited by trez
:worship:
Yeah, and he had a belly encrusted with jewels and ancient gold, unspeakable amounts of wealth lost forever.
Sits as one of the most consistantly accurate representations of GT-R ownership you will ever find in fiction, hahaha.
Some of mine - all at the RAC driving centre though. Almost, almost made it to barbs but then had to pull out due to selling car rolleyes.gif
This thread should be in the Photography section imo with a sticky link in the Motorsport section turned.gif
Edited by 10 4
hard to do this when you've had so many cars... I'll start with my favourite car. the Supra was so much fun to drive:
Lakeside, Hungry corner
Oran Park GP
So why did you sell it, tard :)
The main reason was I found myself going sideways into a gravel trap stopping less than a foot away from the tyre barrier, which made me realise I REALLY didn't want to crash the Supra!
The options were to reign it in a bit and drive at 9/10ths or buy something I didn't care much about, that would be alot cheaper to repair and wouldn't break your heart if it was totalled... A couple of years later that part of it paid off. I couldn't care less that I crashed the 180SX! Well, I cared that I crashed, but I didn't care about the car.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
