Hi Guys,
I have been told to get myself an FPR. I currently have a 30/25 and im running the stock FPR. Which FPR is more suitable for me?
A Rising Rate or a 1:1 ratio?
Current setup is
RB30/25DET
All Stock internals and CAMs
Power Fc
Walbro Fuel pump
SplitFire coilpacks
Turbo at the moment is a stock RB25 turbo and i will be upgrading to a High flowed Z31 VG30 turbo. Should be running around 250-300kwrw once it is tuned.
Cheers
https://www.sau.com.au/forums/topic/380371-fuel-pressur-reg/
You need bigger injectors if you are aiming for above 250rwkw. A bit of a bump in pressure would be fine but you are asking a lot for 300rwkw realistically on a 3ltr. Much past safe.
You don't need to upgrade the reg if you purchase correctly sized injectors too btw, plenty of people running stock regs over 400rwkw.
Still using my stock fpr on my RB30/25 running a Gt3540 with 550 injectors. Currently making 225awkw at 9 psi will be turning it up to 18 -21 psi soon and looking for 300kw+
Will only be replacing the fpr if it fails to keep up - ok so far.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
