One thing though...
Do you guys actually take off the cam cover to hold the cam from turning while slackening/tightening the cam gear as shown in the manual?
Its wierd though because for one they show holding the gear on the outside with some sort of tool, and for the other they show holding the cam itself with an adjustable wrench....Maybe just to illustrate that it can be done either way??
thats because you cant use the gear to tighten with the vct cams on rb25s as its no good for the internal mechanism, you have to hold the cam itself. on normal cam gears you can do it either way
  • 7 months later...
seems like afew guys have been able to change the cam gears without stripping the engine down like your doing a 100k service :)
im going to give this a go in the next week or so, got afew lil ideas/tricks to make it easier...if im succesful il be posting pics
That's what I was going to say!
Do the water pump, belt, idler and tensioner bearings, front seal, cam seals and the bolt and stud....unless you just did a major service less than 20,000km ago!
Why do people replace that stud when replacing the idler bearing? I was going to replace it both when I did my timing belt and then when I rebuilt the whole engine shortly after that (typical!), but didn't as I thought there is no way that would snap.
Has anyone ever heard of anyone either snapping or bending that stud?
There have been a few cases of the stud breaking. Usually due to age (fatigue from belt vibes, stretch etc) or over tightening of the nut.
That is why it's a good idea to replace it when you get the 100,000k service.
And yes, it is easy to change the cam gears without pulling the front of your engine apart. Did a set of cams that way too, just be sure that no.1 cyl is at TDC (top dead center) on the timing mark.
Hmm I should have replaced it, for the sake of $20 for the new stud and nut...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
