Hey mate what state are u looking to buy in?
I've been contemplating selling my r33 gtr, 418kw @all 4, fully forged, os giken box, big fuel system. Basically everything is done. Look at photos in my profile if u want, has also run 10.9 quarter
What sort of budget??
Imaculatly maintained original R32 GTR N1 ( not a mock up it's a legit N1)
Original everything except oil pump, turbos, injectors, fuel pump and nistune. 340kw
Speak to Aaron at import monster. He is selling his personal 32 gtr its midnight purple.call him for all the mods very very tidy and fast gtr.
90080031
No worries I spoke to him today so he will be expecting your call he is very flexable in terms of price,setup,wheels,breaks,iterior,power,everything including transport if your not in vic so give him a call between 9am and 6pm monday to friday! Its an Incedible car!.
Thanks to Drew for pointing me here :)
I'll give you a brief rundown on the car - will miss a heap of important stuff I'm sure - but here's the main list :)
1993 BNR32 - showing 80 something k on the Nismo dash. Unknown original kms but at this point, it's pretty academic seeing as the car retains almost NIL stock stuff ;)
never bent, never in an accident
Full respray in Midnight Purple from Micolour - absolutely flawless paint - piano flat perfection and *just* had the front tidied up for the SAU NATS - so it is unmarked pretty much now (bare metal - probably $8-10k to redo to this standard)
Carbon fibre hood (Proper c/f - weighs about 4.5kgs)
Ganador mirrors
N1 Skirts
Interior
Full custom trimmed Bride interior with Cuga carbon fibre seats in the front, full retrimmed rears, door trims, upper and lower trims, headlining - all in suede with red stitching ($10k to redo interior to this standard!)
RWD Switch in console
Linelocker in console
Also have full dash retrimmed in Suede, but not installed.
Trio of Greddy guages in dash
Engine/driveline
Engine built by Racepace and probably 3-4000kms old. Starts and runs flawlessly. Cold start/hot start = no problems, runs like a dream whether belting it around the hills or putting around town.
Built for 1000hp+ All the usual secret squirrel headwork mods done for longevity on track, bigger sump etc etc. Was making 540rwkw with a big single. Now running custom built low mounts. Around 320rwkw @19psi and zero lag - like NIL lag - exactly what I asked Benno for, he delivered :). All you need to up the power to whatever level you want to make is turbos and injectors and a retune
Can give you a full rundown on what was done to the engine, but suffice to say it had the full house, best of the best build by one of the best GT-R workshops in the country
And the under bonnet style is super clean, nearly stock looking. You could eat off it :)
Big arsed trust radiator
Big arsed trust intercooler
HKS Twin power DLI
Splitfire coilpacks
Apex'i powerfc (a pro if I remember correctly)
Mine's dumps, HKS Frontpipes, Fujitsubo Titanium catback. Decat pipe.
All tuned at Racepace
OS Giken 5 speed gearbox with HKS Triple Plate clutch
Racepace Hicas lock kit (done properly)
Suspension/brakes
Alcon 6 pistons up front - 365mm and full floating disks
Alcon 4 pistons up the back - 340mm I think. Bigger than most fronts
Tein RE given the full custom Racepace rework. Incredibly easy to drive on - maybe 1000kms of use on these
Nismo Circuit link setup
Am flexible on the wheels, I have many. Right now she has Rays Gramlights 57F Pro in 18 x 10 +13 and brand new Kumho KU36 rubber
Here's a pic taken a couple of weekends ago at the SAU Nats, feel free to drop me an email/pm/phone call if you want to check her out. :)
Cheers
Aaron
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
