Just installed a AFR display today and it was reading 13.5:1
Is this a normal ratio? My fuel economy has been pretty poor as well :/
EDIT: Shit, Must I add I'm running a R33 GTS '93 RB25DE
Only mods is a K&N high flow panel filter & the muffler replaced with a cannon.
Thanks guys.
Edited by S3RK
https://www.sau.com.au/forums/topic/380458-running-too-lean-on-afrs/
If it's only the gauge connected to the factory sensor, then ignore the gauge. It's designed for a wideband sensor, not a narrow band sensor, all that they can read is "Lean, Stoich, Rich" they don't return an AFR.
It's one that actually displays numbers, but I'm having a few issues with it so it's not actually displaying the correct ratio -_-
So what should idle, cruise and full throttle be, just good ratios that won't hurt the car?
Is the only thing that you purchased, the gauge? Does it have a new sensor, or does it wire into the old sensor?
If its using the standard sensor, you remove it from the car, and throw it in the bin. It will be as useful in the bin, as it is in your car then.
as above, how do you have it hooked up? if it's simply running off the stock o2 sensor then ignore it as it won't tell you squat, except for at light load when it may tell you whether your o2 sensor is working properly or not.
^All of the above, it was given to me, the jaycar one that you build yourself. It's hooked up to the ecu wire.
I hooked up my ecu cable today and ran a error test, apparently my knock sensor has an error for the last 25 starts (I believe ECU holds up to 50?)
and roughly 25 starts ago I had to take my car to the mechanic, he is a dodgy mechanic but I was forced to take it there. After he replaced my clutch there was a red light for the exhaust I believe on the dash, so I asked him wtf is this shit and he raises the car back up, pulls this cable out of the cat converter (I think) and rips the inner wire completely out and puts the cable back in, then tells me it's fixed. :/
I believe that's the secondary o2 sensor? Does it affect the car in any way?
Where abouts is the knock sensor located? and can I replace it?
Thanks in advanced
That was the temp sensor for the cat. It comes on when exhaust temps are way to hight (ie a blocked cat). Has nothing to do with O2. It simply just brings the light up on the dash.
It sounds like you have just put a AFR gauge onto a stock narrow band sensor. Meaning it is absolutely pointless.
Yeah sounds like its reading off the stock sensor. If you want to check your AFR's I'd suggest taking it to a tuner and spending $100 putting it on a dyno and getting them to tell you how it is. If its just a stock ECU this would be your best option, but it shouldnt be running lean.
If aftermarket ECU then I suggest getting a good quality wideband kit.
BTW 13.5:1 sounds rich if anything for an NA, probably about right on stock ECU
Nope.
However the fact the light on the dash came on could be an indication of a collapsed cat.
in 99% of cases though it is caused by the sensor being dodgy. mine used to come on the moment i started the car, so unless someone had stolen my car and parked it a few seconds before i walked out the door to go to work i was pretty sure it was a dodgy sensor, LOL
Thanks in advanced
If it's not had a replacement sensor placed in the dump pipe, do yourself a favour, remove the AFR gauge, and forget you ever started this thread.
+1
And the cat sensor is uselesss on 99% of highflow cats because there is no point to install it so maybe invest in a highflow cat and forget that the mechanic ripped it out? Exhaust shops tuck the sensor under the heatshild when fitting the cats so they are simply installed for someone to say "hey my cars got a warning like, better take it to the mechanic".
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
