IVE HAVE PARTED OUT MY S13 SILVIA NOW ALL THAT LEFT IS THE SHELL.
ITS BEEN PROFESSIONALLY PAINTED IN TIGA MICA INSIDE AN OUT
ITS GOT A CARBON FIBRE BONNET AN BOOT
WIDER VENTED GUARDS
MODDIFED VERTEX FRONT BAR
DO LUCK SIDE SKIRTS
NISMO PLASTIC REAR PODS
ADJUSTABLE REAR CAMBER ARMS
THE CAR HAS A FACTORY SUN ROOF
INTERIOR IS IN PRETTY MINT CONDITION
CAR WAS REGOED UP UNITL 2 MONTHS AGO SO CAN BE RE REGO
BATTERY RELOCATED TO BOOT
STUFF MISSING
FRONT SEATS
MOTOR AN BOX PLUS ENGINE LOOM
CLUSTER
EXHAUST
COILOVERS
WHEELS
RADIATOR
THE CAR IS SITTING IN MY SHED ON STANDS ALL TOGETHER BESIDES PARTS ABOVE BEEN REMOVED
YOU WILL HAVE TO BRING YOUR OWN WHEELS AN SUSPENTION TO GET IT ON A TRAILER
LOOKING FOR 2200ONO
SELLING CHEAP AS I NEED IT GONE ASAP GOTTA MOVE HOUSE BY 7TH OF DEC AS THE HOUSE IAM RENTING HAS BEEN SOLD
MSG FOR PICS ON 0417054081 CAR IS IN HORSHAM VIC 3400
https://www.sau.com.au/forums/topic/380478-s13-silvia-shell/
also has rear wheel arch flares
no discs or calipers
i will do swaps plus cash
looking for sr20 or ca18 wheels a set
also a set of good condition coilovers
so if any one wants stuff off it but low on cash let me know what you have we can work some thing out
or any hr31 tail or head lights
also there is a standard boot lid painted same colour to go with the car
head an tail lights all there in good condition
surely some one needs stuff!!!
