hello fellow members, it is my first time on this site, i have a r33 skyline gts-t and i wish to paint the calliper covers on the brakes. do i just mask around them and paint them. or do i best take them off to do it. i tried undoing the 4 bolts at the back too see if the cover came off and brake fluid started dripping out so i quickly done them up again. i an not mechanicly minded so can someone please help me, thankyou.
https://www.sau.com.au/forums/topic/380496-paintig-brake-calipers/
hi mate, welcome.
You can take the caliper off if you want to be meticulous but wouldn't recommend this unless you are familiar with refitting them and bleeding the brakes etc. You should be fine to give them a good wire brush and clean to get any shit off them, then mask the area around the caliper with newspaper and rags. Make sure you get caliper/heat resistant paint.
There is an in-depth tute around if you want to do a search.
Just so you know, there should only be two bolts holding the caliper on. So you were most likely undoing the bolts that hold the two halves of the caliper together, which is why brake fluid went everywhere :P If that's the case, you may have let air into the system, which will require a bleed. But cross that bridge if and when you come to it, otherwise SonnyQ is spot on thumbsup.gif
i got carried away painting mine on saturday, pulled them to pieces..but the finish is good..
heres a pic of all the parts, really is pretty simple..the 2 red arrows are the bolts to take them off the car..
if you have split them you may as well take them off now and clean them up.. pulling them apart is easy just pull the spring pin and the pads all come apart, then undo the 4 bolts and thats about it.. throw all the bolts and stuff in some cleaner something caustic will eat away the grime or just scrub them with brake clean..check your seals around the piston while your there..
getting the brake line off is the trickiest part..find a good fitting 10mm spanner and lightly tap it with a hammer until it gives..just take care and do not strip it..
heres a finished one..it really is easy just be careful not to strip bolts..
:cheers: i dont think they're too bad for a quick job..
if you want to get carried away you could get all the bolts/parts replated or chromed, deburr the casting marks etc and powdercoat the calipers they would look much better than new..
its not worth the effort in my case...buts its good to practice, never know I may have a worthy vehicle oneday..
i did the fronts this arvo, didnt bother pulling them in half though..
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
