Guys,
This is what I'm currently planning to get for my 33 gtr - any suggestions and advice, if something with this setup is NQR, I would appreciate.
  • xforce front pipes - 2.5" into a 3.5", stainless
  • 3.5" xforce cat, stainless
  • 3.5" cat back with the middle muffler, mild steel
  • xforce muffler 3.5" into twin 3" outlets, stainless
Got a fairly reasonable quote so am considering getting it, middle section is mild steel mostly to save some $$$.
https://www.sau.com.au/forums/topic/380537-exhaust-suggestions-r33-gtr/
have you done you dump pipes?
what kind of flow does the xforce cat flow? 200cfm, 400cfm or more?
try get the front pipes in mild steel, no need to be fancy under there
Ho, have not done the dumps yet. Was just thinking of leaving them stock. Good idea/bad idea?
Those front pipes are off the shelf in stainless, made by xforce, otherwise I'd get them in mild steel too. This exhaust place was saying that they can make them out of mild steel, but I was just worried about them getting the lengths correct. Should I worry about it or not?
I threw a 3.5" Xforce cat in my R32 GTR along with Trust front pipes 70mm into 80mm, and straight away made a big difference to the mid range even with the standard turbos that were on at the time. I got the cat from Just Jap and they say they flow at 880cfm. Not sure how that converts into cells per square inch (CSPI) though. Is there a conversion?
Don't bother with the dumps until the time comes to swap out the turbos, bit of waste of time and effort - alot of effort, considering the end result is of no big gain.
Edited by smithy85
How modified is your GTR?
Don't bother doing dump pipes, stock are fine (I made 302rwkw with stockers).
If you want to do dumps, do it when turbos are out, just to make install easier.
Its not modified at all, stock as except for K&N airfilter element - and yes I'm thinking if I ever get some -7's then I'd do the dumps, until then stockies remain.
good idea, theres alot of other things to do first that will give better and easier gains.
Right now I'm thinking fitting that exhaust, then boost the stock turbos a bit more than the current 11psi, but not crazy high to see them break apart - I'm thinking 15psi.
Then get the adjustable cams and get the ignition timing adjusted on the dyno. Since I already have K&N I think this should make my baby breathe much easier and go much better.
I know its power will not be anywhere near most other GT-R's on this forum but I'm hoping for a 180-200kW at the wheels - if I'm lucky :whistling:
If you are only getting -7's why not stick with a 3inch? It will flow enough for the -7's and at the same time you could build a nice quiet exhaust which is a lot easier to do than in 3.5 inch.
I'm not really planning to get -7's in the next 12-18months.
Reason why I'm going 3.5" is since xforce kit is 3.5" front pipe.
Do you think that even with the suitable mid-muffler and large twin outlet rear muffler this exhaust will be much louder than the 3"?
Two decent mufflers in any system, even 3.5", is usually enough to maintain a respectable noise level.
Start removing mufflers on the other hand and the real RB noise starts to show :D, which is the route I took:
- I went from a 3" mandrel bent system that had a small hotdog plus a rear cannon and changed it to a Veilside 3.5" JASMA which actually made it quieter (EPA tested at 91db) because of the two monster mufflers it had. Then I got sick of the over-muffled noise and got rid of the centre muffler and that has given a nice balance of relative quietness during cruising plus a good "bark" when its punching holes in the horizon!
Would have gone Blitz all the way from the front pipe to the tip but Xforce isn't a bad Aussie product.
Changing the front pipe on a tuned SR makes a difference apparently but not sure on an RB. Xforce do make a metallic 100 cell cat in a 3" setup, don't know about 3.5" though.
Either way, you enjoy your setup mate. If noise is a concern either throw in on nice big muffler box and / or an Apexi ECV 95mm. If you're game try one of those velocity pipes that have a smaller diameter but flow better with pressure.
Edited by Ruff Ryda
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
