Just did compressions on my r33 and got these rather low figures
1 - 105
2 - 108
3 - 105
4 - 97
5 - 110
6 - 106
Tried cylinder 1 again with some oil and got near 200psi, does this indicate my rings are worn to the $hit house ? it uses a bit of oil here and there aswell
Edited by Slattery Gts-t
https://www.sau.com.au/forums/topic/380541-low-compressions/
  • Replies 58
Yeah its the lowest iv ever seen across the board in the few iv tested
How much is involved in changing the engine in an r33? taking into account i have acess to a hoist, full toolkit and a few extra hands
I think the gauge is pretty accurate because our compressor reg is set to 100psi and when i sealed the air gun to the gauge and shot 100psi threw it the gauge went straight to 100psi
Im pretty confident my engine is shagged lucky it still runs alright, my odo shows 117,000 im taking it that this is wrong or is it not unusual for this to happen to these engines at these kms?
Haha oh well that gives me hope that it will last until i organise another engine, Only had this car a few weeks and from the start iv always thought it was lacking power especially off boost well this explains it
My engine had 140,000kms on it and 50,000 of that was at 300rwkw.
Compression test came up at 160psi across all 6. It only had a 2psi variance.
Seems that car has had the shit flogged out of it. Surprised it hasn't blown number 6 yet.
  • 2 months later...
Just thought id update
I was nearing the end of a 300km trip on saturday when all of a sudden there was a loud 'clunk' followed by lots of quieter "clunks"
First i though it must be bottom end related as this was unhealthy to start with but turns out my timing belt jumped a tooth on the intake cam and mashed a few valves
It only jumped one tooth though is this usually enough to smash valves ? now compression figures are around the 50psi mark with cylinder 4 showing absolutely nothing
Im replacing the whole engine it just didnt get here in time before this one shit itself
But your right because i plan to rebuild this engine and now i may have damaged the head
Lance: thats what i thought too so its got me buggered, im certain it was spot on before it happened
This is why you refresh a buggered engine - only costs a lot more when you have to start repairing damage. Especially bent valves.
yer damn that low compression putting all that extra strain on the timing belt.....:stupid:
1 tooth isnt anywhere near enough to mash valves, are you sure its only 1 tooth?
what about if the car has some aftermarket cams? wouldnt that make the compression drop , my first car had the cam reground and the compression fell from 150psi to 110psi,
that would explain it having fairly low km's and down on compression...:ph34r:
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
