hey so this is my first post here on skylines au. im from canada and ive been trying to figure this one out for months now and nobody over there can figure it out so hopefully one of you guys can help me out with your wisdom!
okay so heres the problem:
i had an rb20det in my s13, then blew the head gasket on that motor, so i went and got and series 1 rb25det motor. i swapped that one into my s13 and its running great, but missing some power so i go to figure out how to hook up the vct. im still using the 5 speed rb20det wiring harness, and am using an automatic rb25det ecu series 1. since the rb20det doesnt have vct i read the wiring diagrams, and added a pin to the harness on pin 113 for the vct function. i ran that wire to one side of the vct solenoid, and the other wire on the solenoid to switched 12V. but the vct still wont function. i meter out the soenoid harness and i get 12v swtiched on one side, and no ground continuity on the other, ive tried it as im driving, idling, reving, but still no ground coming from pin 113. i opened the ecu and metered the circuit board to the solenoid plug and there is continuity so i know the pin is connecting. at first i didnt have a neutral sensor hooked up but i read i needed that so i wired the neutral gear switch pin to ground so the ecu always thinks it is in gear, but it still will not make vct turn on. i have a speed sensor connected aswell and still nothing. i tried a 5 speed ecu aswell but it didnt change anything. i cannot figure this out please someone help me i am about to throw my rb25 off a bridge because i am not getting anymore power than what i already had with the rb20!
https://www.sau.com.au/forums/topic/380549-vct-issues/
I have seen a shift light converted with a relay to switch the vct and it was ajustable with the shift light control you might want to try that or a rpm switch could also be a lack of an earth somewhere in the loom
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6069658
If you don't have the speed signal fed to the ECU correctly then you won't get VCT either. I have heard scuttlebut that the speed signal that is output from the R32 dashboard is not compatible with the RB25 ECU, so I would hazard a guess that if this is true, then it would also be true for the S13.
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6070508
dont forget NTR must be OFF for VCT to fire
ie if your in nuetral or you havent wired in the NTR switch, the VCT wont engage
from memory
#DEFINE VCT 1
func main(void)
if(RPM < 1800 && ! switch(NTR))
func(VCT);
return;
i dont think its speed related at all ?
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6071096
yes the solenoid is working it has 12v, and i can manually ground the vtc pin and it will enable to solenoid and the idle will change, i was messing around with my friends series 2 rb25, and he dosnt even have a speed sensor on his car, and it still works, i unplugged his coolant temp sensor and vtc still works, the only time i can get it to not work is when i unplug his tps, but its a different tps than mine cause im series one. so it has a different plug i can just swap them to see if it makes a difference, i tried a different ecu in it and still wont work, and tried a z32 ecu in it and it wont work either
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6078553
does the ecu get the speed signal from the speedo and the speedo get the signal from gearbox?
thought it would be the other way around?
anyone know the pin outs? need to get it working on the r32
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6079003
in my s13 the signal goes to the cluster, and then to the ecu from the dash plug.
k i think i have found the issue here... when i put my greddy intake plenum on my motor i had to extend some plugs for aav, fcid, and tps... there was a second tps plug and i read to cut it off cause it was for the automatic gearbox... but i was going through the ecu schematics and i found something called a throttle valve switch, that isnt the tps... so i did more research and apparently it uses the same plug on the tps that the auto gets the signal from. i figure finding this plug and hooking it into the tps will make my ecu happy and turn vct on =)
ill find out tomorrow hopefully it all works ill be the happiest rb25 owner ever
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6079099
If not, the msd window switch, or nos rpm switch, vct controller etc is a good option.
I had an issue in my r33 where the stock ecu would not control vct properly, after a turbo and fuel upgrade I got a nistune on an rb20det ecu and use a nos rpm switch for the vct, works better than it ever has.
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6079354
ALRIGHT VTC IS FINALLY WORKING!!!!! after so long messing around with it i finally got it to work! so series 2 rb25det uses the tps to sense when it is off idle and will kick in the vtc, but SERIES 1 dosnt! it has a "throttle valve switch" that uses the same socket as the automatic tranny tps plug. so the 3 pin output on the series 1 tps needs to be connected to sense that the motor is off idle and therefore making the ecu happy to turn it on. so i wired pin 57 and pin 54 to this socket and voila! vct solenoid clicks when i tap the gas =) thanks everyone for trying to help me out i very much appreciate it!
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6080600
speedo drive => cluster => ecu.
on the ecu side on a 33 its a green wire with a yellow trace iirc, 32 should be the same. not sure on compatibility between models though if your running a rb25 etc
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6080706
Earthing the neutral pin is incorrect also. The input drop's to earth when neutral is used therefor disabling vct.
no earthing the neutral pin is correct, when the car is in any gear the neutral sensor senses ground, and there is no continuity when in neutral, so rather than having my timing pulled around when going in and out of gear, i just grounded it to make the ecu think its constantly in gear.
https://www.sau.com.au/forums/topic/380549-vct-issues/#findComment-6081076
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
