hey all, just did a turbo swap on my stagea, stagea Neo OP6 turbo swap with a R34 NEO OP6 turbo.
the r34 turbo has a plasic feeling front wheel (it is also black in colour), also has a flex in it when pushed. was guessing thats the case since people say the front is plastic and rear is ceramic.
now my stagea had a different front compressor wheel. My guess its a alloy wheel as it isnt attracted to my magnet. its heavier and also has no flex in it
so im just trying to research if there was a different front wheel used in the stagea compared to a r34, or possibly if they had a revision of turbos through series 1 and 2 of the R34 skylines......
i dont know what year model the r34 turbo came out of, but my stagea is a 2001 build
so does anyone have pictures of their stagea's turbos?? plastic or metal wheel??? or any info at all??
also as a last note, my turbo is stock, not high flowed.
Maybe post up a pick of your turbo. Does it have any other markings. How many blades does it have and are they twin or single blades?
Mine was just the normal nylon/plastic comp wheel with the ceramic turbine. I have a 99 model.
looks like the same style as the steel wheel compressors in the early model R33's before they changed to the nylon/plastic ones. i remember reading that one of the series's of the R34's had a steel wheel compressor, maybe the Stagea did too.
just found it. check out this link
http://www.skylinesaustralia.com/forums/topic/69089-differences-between-r34-and-r33-turbo/page__view__findpost__p__1527454
aaah, indeed. well i guess it isnt steel. steel is attracted to magnets right? so alloy? also i didnt know there were 3 series cars. always thought that both r33 and r34 both only had 2 series each. i will see into this some more. also my nylon plastic turbo has twin blades on the front, just like the alloy one
Yeah the nylon ones do have a second fin but it's not as prominent as the steel ones, you can't really notice it looking down the compressor inlet.
Yes it will be some kind of alloy, I don't know what though. It all depends on the steel as to weather its magnetic or not ie stainless steel isn't magnetic.
I don't think the stagea followed the R34 and had a 3rd series, it's just an R34 thing. Apart from the garret turbo I know the fuel/ign mapping is different on the S3 R34's, I've compared the base maps of the R34s supplied with nistune.
Edited by QWK32
really, r34 had 3 series? wow, but they had a short lifespan, 98-01 right? so one year per series nearly. all i know my compressor housing says 45v3 so makes sense. wonder what the power difference was between the 3 series's, turbo lag and fuel consumption.
here are some pictures, i dont know what those random marks on the rear of it are though
The marks are where material has been removed to balance the impeller.
There is nothing per se wrong with a composite material impeller; it's cheap to manufacture, nice & light, which would aid response, and it's unlikely to destroy the housing or the engine if the centre bearing fails.
The only time it might be an issue, would be if you were to grossly overspeed the assembly, but I'd expect the ceramic exhaust turbine would fail first.
when i had my turbo out it had a black compressor wheel
pretty sure thats the nylon front wheel that all s2's and r34's should have
yours have have had a turbo swap at some point in its life
yeah, i havnt had a turbo swap on my car, 100% sure on that, that thing was sooo rusted into the manifold, sure it was stock.
im guessing that 2000 onwards or late 2000 models had a steel wheel. I was pretty surprised when i found out should have swapped front wheels on the turbo, now im scared that plastic thing is gonna blow off. im running 13psi, might need to turn down now.
Should be alright, I ran mine stocker on 13psi, although only for about 6months until I upgraded it. I also ran a plastic wheeled R33 turbo at 14psi on my R32 for years without it failing.
I'll have a look on Nissan fast later and see what turbo part numbers I can find. But I reakon they followed the r34 and went to steel wheel in the late models.
had a look in Nissan Fast
it lists 14411-AA100, the plastic wheel one, on all stagea's 08/98 and up. so all S2's. it does however list the 14411-AA110, the steel wheel one, as an alternative part number.
also a bit of useless info, in my version of fast it lists a replacement turbo at ¥120000 = $1516.
so i wonder how the steel wheels managed to get stuck on the stagea????? maybe had some extra steel wheels floating around and nissan said lets just throw em on random turbos.... bahaha
id rather buy a garrett turbo than spend fkn 1500 on a stock new one......
probably popped when it was newish in japan => warranty replacement or somesuch
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
