This years Jamboree at Willowbank on the 21st of September will see the inclusion of import 6 cylinders. I am racing my R32 and my mate will race his S13 (RB20DET).
We have spent a lot of time on the dyno of late and have finally got the HKS cam gears dialed in to perfection. We were able to get 15rwkw EXTRA right accross the rev range which took the power figure for the RBS13 to 232rwkw @ 18psi. My car will go in this week for the gears to have their final tune and the timing advanced for more power and torque. I have also made some significant changes to my car since I last ran.
On my last run (13.7) I had my TEIN suspension which prevented the rear of the car from squatting thus stopping vital weight transfer. I have since replaced these with some stock shocks and springs, the car really squatts and launches much better and the general ride is heaps softer but cornering is not quite as good. After Jambo I will fit bigger sway bars and slightly lowered springs while still maintaining the rate.
The second area of attention was the tyres. I have 18" rims and would like to keep them on for the drags to show the true performance in street trim. On my last run I had 235/40/18 FALKEN ZE326 tyres which were badly worn and on a huge negitive camber so grip was not good and prevented me from launching over 3000rpm. I have replaced these with 235/40/18 FALKEN ST115 AZENIS which are nice and sticky and should solve the traction issue as well as possible without going to semi slicks.
The third area was the clutch, a new custom built DCS ultra heavy duty single plate was made and installed and now the car drives like a new car.....I now know how much power I was loosing through undetectable slip. Chirping third when driven hard the clutch is only 1 week old and will be good for some quick times at the drags.
The final thing I have changed is the top intercooler pipe from the throttle body to under the battery, the original one had a couple of small leaks and now with the new one installed the car is pulling really hard.
After the dyno tune this week I will post the findings. I have decided to run a higher ron fuel for Jambo as the qualifying is during the day and I don't want to risk any detonation in the heat. I am also removing my cat and dumping the exhaust out under the car for that added sound effect (has no effect on performance)
I wish everyone luck at Jamboree and hope to catch up with you all.
Cam & the DUEL guys.....:D
Well! Well! Well! .......going for it eh Cam,....don't line up beside me will you :D I had some plans but, alas , I'm in the same state as Dragcombat. Haven't even been able to get it on the dyno with toluened fuel. I was mainly hoping to get some practice in so I could work out an achievable dial in time but didn't manage that either............. anyway I'll see you there.. Break a Leg :(
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
