I'm trying to sell my track only r32 gtr it is in for sale section with pics
I may split it all out if I can get buyer for engine or shell
Rolling shell 4500
Rb26 big hks single setup 6000 with power fc dejetro
gearbox and brand new clutch 1000
Pm only if interested in major parts after one sold I'll update with list of parts
Centra coast
0411672105
https://www.sau.com.au/forums/topic/380604-r32-gtr-track-rolling-shell/
Rolling shell 4500
Centra coast
0411672105
i may be interested in the gearbox, how many kay's, any work done to it? and what sort of clutch?
Clutch is 4 puck solid center comp clutch single plate brand new. Unsure or gear box never got the chance to track it I think its 120000km only sell if car or motor sells
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
