  • 2 years later...
nah its the diesel... has no go off the line. car feels very heavy.
nice to cruise tho.
you might think it's a little slower because you're used to a faster car. But 320nm of torque in a 1.7l turbo diesel motor is awesome. You can get 1500km to a tank of fuel highway driving in one of those too. I sell Hyundai's and i'm currently driving one for a drive car - i think it's great i enjoy driving it every day. Nice and smooth comfy and power is great.
The question you have to ask is; if you can get 320nm of torque and 1500km per tank from 1.7l,
Why wouldn't you make it 2.2l or 2.4l with a wide ratio box, & actually have a car that goes fast AND gets good fuel economy?
Cause mazda already did that with the 6 diesel. 2.2 litre 130kw 420nw 5.4l per 100
And Hyundai owners are povos, that wouldn't pony up for a mazda.
Would not buy.
If you found out the cost of servicing and replacement of parts on these modern diesels you would freak, the particulate filters alone are worth 3-4k and can block every year or two.
I punched one out the other day as it was clogged, the customer couldn't afford the 4k for a new one from Subaru. So happens there are temp sensors in there to help diagnose the burn off phase, without the medium in there this doesn't happen well at all obviously. When the fuel gets dumped to do the clean the car now goes into limp mode. :/
Love a bit of engineered failure; how else can you make money out of reliable cars?
My point exactly.
Add to that the stupid direct injection issues of carbon build-up around the intake valves and you have some serious maintenance issues, cars are definitely not designed to do half a million k's anymore, not without massive servicing costs.
5 year unlimited km warranty, 7 year roadside assist, 3 years capped price servicing (15,000km-12 month intervals) full size spare better put together interior (easier to navigate and more updated), better features, better value for money and a better looking car is a handful of reasons why i'd buy an I40 over a dolphin-nosed Mazda.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
