hey guys
most of you that have upgraded wouldn't wish stock gts brakes on your worst enemies
but i want some, for my 31
the wheels i have won't clear 4 pot brakes so im chasing something with a sliding caliper
let me know what you have and how much
Cheers, Tom
https://www.sau.com.au/forums/topic/380628-wtb-cheap-non-turbo-brakes/
ive got a full set of stagea brakes. twin pot fronts single rear. with pads and rotors. u can have the hole lot for a 6pack of strongbows
s1 or s2? i tried to put my old s2 fronts on but the mounting holes are hardened so can't be drilled
hi mate, ive got a full set of r34 na brakes with pads and rotors you can have cheap, let me know if your interested
same as above, your 34 ones won't bolt on because they use 14mm bolts and i already tried to drill them out but they are hard as!!!
running import/gts front struts so probably no go on that one too :(
can't be 4 pots either (any future posters) because they won't clear under my watanabes pinch.gif
ok well i have some 2 piston slide type calipers ive just talkin off my infinti in favour of 4 pots. throw me an offer via pm or text 0401396905 if you want :) have rotors and pads. rotors are in poor shape from sitting around for now 8 years.... lol but they can come with or go in my bin your choice. all located on gold coast.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
