Provisional Drivers To Be Banned From Driving On Friday, Saturday Nights?
  • Replies 75
There will be some sort of exemption policy for people who need to work, that article posted earlier even made vague reference to it... can't imagine it being free though
So 16% of the drivers cause 25% of accidents hey?
Well, whatever you do, don't train the remaining 84% who cause 75% of road accidents.
Training the majority, that'd be just stupid.
Here ends todays sarcasm lesson.
Love it
LMAOOOO legend
Side note; I dont see how a 17yo can be a fully licenced driver. Care to explain please?
EDIT: Just to confirm, by open license you mean no P plates and no L plates with the maximum available of 12 demerit points on your license?
Im from New Zealand, where we get our full licenses at the age of 16 and a half,
before moving over i rang up the transport agency and they confirmed im eligable for my opens.
So, in other words, they're discussing bringing in a new rule, but with more and more conditions that will make it more of a PITA to manage and enforce...
So, each police officer will have to:
  • check age of driver
  • check level of provisional license (P1 or P2)
  • check if there are any passengers who shouldn't be in the car
  • check that they're not in a restricted car for their level of license
  • check if they have an exemption to drive that car if it IS on the restricted list
  • check if they have an exemption to drive during those hours on a weekend
Where will it end?
Here's a thought...
All of the bans and restrictions they have implemented, or want to implement, are because they're not used to driving to said conditions/with power etc...
So what happens at the end of said restriction when they are 2 - 3 years older and STILL haven't driven in those conditions?
Here's a thought...
In theory they're older and more responsible. Of course some people never change.You might say that those some people were the ones who were causing all of the accidents before any of the restrictions though.
Edited by sneakey pete
Here's a thought...
Yep, older and more responsible (the majority, anyway, as you mentioned), but the inexperience is still there as Matt pointed out.
It's a well-known fact that the older you get, the harder it is to learn new things and pick up new skills.
Very kind of you to make your comment general rather than specific. :P
(now how did I get that left heel scrambled up with my right toe)
I may be older and more responsible, and now set in my ways... But is that going to make me able to drive in heavier traffic of a night when I've never driven in it?
Or how about when I do get in a car with 4 passengers that I can drive for, how do I get use to them all talking when I've never experienced that before?
Education and attitude bending is the only way to fix bad driving and reckless driving...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
