Going to brief here..
Km's: 85 ***
Colour: Honey gold
Price $15 000
Contact: 0404 513 631 (serious buyers only!!!) don't answer forum email very often..
Some of the mods include:
Fresh respray in honey gold nissan factory colour & not one ding! Door jam inside & out job, Just needs front bar to be painted as i changed the bar back to factory
Clean interior with recaro(some wear), gear knob, wheel & boost gauge.
BC coilovers
Brand new slotted all round disks, pads & fluid
New nismo turbos!!
New studs everywhere, turbo/dump/manifold gaskets/fuel filter/oil filter/oil etc...
New JJR stainless front pipe
K & N intake kit
Splitfire coilpacks & sparkplugs
P45 18 x 10 new wheels with new federals all round - 265 rear/235 front.
Calsonic front mount cooler
750cc denso injectors
Bosch 040 pump
Motor was rebuilt 10 000kms ago
Full exhaust
Hicas lock bar
Turbosmart boost tee
& more...
All the car needs is a tune & for the injectors & new pump to be put in. Also the front diffs seal is worn so i just drained the fluid out and it is in rwd mode - this is a cheap fix just a $20 seal or so... have no money anymore due to uni :(
Fully engineered just needs rego
This is shit cheap considering i bought it for more than this and have spent nearly 10 grand
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/
Your joking arent you..... you do realise you will stuff the diff driving it with no oil in it!
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/#findComment-6069261
Then thankfully your not working on my car!!!
You do realise that the front drive shafts will still turn the diff over and the bearings in that diff need oil to lubricate them regardless of if they have drive from the engine or not..... in order to stop the diff turning over you need to remove the front drive shafts and you cant remove the front drive shafts to stop it from turning as the wheel bearings will come apart....
get some oil in it and live with the leak or you will seize the diff
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/#findComment-6069437
Ummm mate i'm not like some nub i have done heaps of trackdays set up with my own work.. I have not driven the car since there has been no oil in it. note that it has just had turbo's redone, fuel etc... I have pushed the car around and driven it once up into my driveway before i did all of these mods so i believe they would be fine. I let it drain out so i don't put a few litres of oil on my garage everyday from the leak lol, hence why i said it must be fixed, there is still a few hundred ml's in there. Thanks anyways but :)
Edited by tyr33
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/#findComment-6069456
Should have said that in the first place then as that changes the whole thing.... fair call on not wanting to unload the diff oil on the floor, but as i have said, simply pulling the fuse does not mean that the front diff needs no oil. Which you seem to think is the case.....
Just some friendly advice thats all mate. I have built more of these things than i care to think about and would prefer to say something than see someone seize a diff
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/#findComment-6069461
So have a swap lined up for a weeks time roughly but there is another car i really want which still allows me to pay off debt, true story...
$11 800 !!! This week only as if not i'll be going ahead with this swap, Crazy cheap for a gtr in this cond! No damage, solid motor...
Call 0404 513 631
https://www.sau.com.au/forums/topic/380646-1989-r32-gtr/#findComment-6086633
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
