Hi guys..obviously from a different manufacturer but might as well spam my car for sale
Car specs:
1997 Toyota JZX100 Mark II
Colour 057 pearl white
Factory sunroof
All factory options including auto lights, rear wiper etc
5MT (converted professionally in Japan with fresh clutch)
Torsen LSD with 3.9 auto gears and fresh oil
~120km on dash (still has original dash, 100k service completed at 88km)
Exterior:
Vertex half-bar kit (bit rough)
Series 2 tail lights and boot
Series 2 head lights and corner indicators
Clearworld front indicators
Green/aqua reflective tint on rear windows
Interior:
Bride Brix 1.5 drivers seat with genuine rail
Gang*Star white steering wheel
HKB boss kit
Pink LED interior lighting throughout
Leather seat covers front and rear seats (have standard drivers seat in storage)
Aftermarket gear knob
Juran drift button
Apexi boost gauge
Sound:
Sony 7" touchscreen head unit (plays dvd/ipod/aux)
Polk/Momo front splits and rear speakers
Kicker amp
Alpine sub
Performance:
Origin intake pipe + pod filter
3" AMP dump/front pipe
3" Apexi N1 cat-back
FMIC
HyperGear 3076 spec highflow turbo with braided lines
650cc Power Enterprise injectors
Walbro GSS342 fuel pump
Power FC + hand controller
Tuned by Trent @ Status tuning - 247rwkw on full boost 19psi
Wheels/Susp/etc:
18x9 +22 / 18x10 +33 Weds Kranze LXZ in mekki chrome finish
Greddy Type-S coilovers
Greddy EDFC (in-cabin damper adjuster)
TRD front + rear swaybars
Fresh QFM A1RM pads
Most recent pics:
IMG_8099.jpg?t=1316104811
Extra info:
Honestly there's probably more bits that I have left out or forgot. I imported the car from Japan in 2010 and have done everything myself with the exception of the turbo swap which was done at Chasers. Mechanically the car has always been well looked after, serviced every 5km with Mobil 1 and plugs changed. I would like the car to go to a good home as I have put everything in to this one but it is time to move on in life. It is an honest car and I am happy to disclose any imperfections. The points about the car that could use some attention;
-Inside-out pin dent in rear 1/4 from flying jack in boot and paint has flaked (common jzx problem)
-Front passenger guard is a bit rough
-Kit is not in the best condition (cracks in front/rear lips)
-Bonnet was replaced after I found someone had reversed into me at uni and left no note, was very minor and slight bend on old bonnet. Needs bonnet latch alignment.
Either way the thing washes up well, has good power for daily driving and handles well. I am negotiable on price with removal of parts. Will shoot some more detailed nice pics of the car soon.
Price: $23,000 ono (will reduce price without wheels, sound etc). This includes registration until August 2012. The car is currently defected for ride height but this will be cleared next week and RWC provided with sale if sold before it expires. Please no offers for swaps besides something like a spec'd up Accord Euro or Liberty.
Contact: 0424 141 211 (Please call after 8.30pm or SMS as I do not check PM's regularly)
Michael
Edited by discern
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
