Hi Everyone!!
My car is a 98 ER34 GTT I had recently upgraded my stock brake line to NISMO brake hose, and using Endless brake fluids. I find out after driving there is oil leak from the bottom of the car, does it happened into any members car in here?? Need Some Help ASAP.
https://www.sau.com.au/forums/topic/380680-need-help/
Yes, it is critical to know whether the leak is brake fluid or not before you drive the car again.
If you sit in the car and pump and then hold the brake pedal, does it slowly sink to the floor? If so you have a brake fluid leak somewhere that you need to sort out before using the car again.
And if you aren't sure, get a mechanic to check it.
https://www.sau.com.au/forums/topic/380680-need-help/#findComment-6069807
Check the brake fluid reservoir - is it low? Follow the leak back to the source. One of the lines may be a bit loose, but you should use a flare nut spanner to tighten it as open enders can damage the fitting. If fluid has leaked onto the pads you'll have to replace them as well.
https://www.sau.com.au/forums/topic/380680-need-help/#findComment-6070118
I had same problem when I had my Nismo lines fitted, I didnt notice a leak but I noticed 24hrs after my fluid was about 4mm below the max line. Mechanic tightened up all 4 corners and since then I haven't lost a drop
https://www.sau.com.au/forums/topic/380680-need-help/#findComment-6070545
This thread is a clear example of not f**king with stuff when you don't know what you are doing. You could have killed yourself or someone else if the brakes failed and without fluid they fail. Next time you need work done to critical parts of the car like the brakes either know what you are doing or don't f**k with it.
Sounds harsh but seriously count yourself lucky your car ain't written off or worse.
https://www.sau.com.au/forums/topic/380680-need-help/#findComment-6073315
haha you sound so mean, but I didn't change it myself, the car was in the workshop for few upgrade and the guy from the workshop told me there is oil leak after the lines were fitted, so I just want to know what cause the problem. if anything lead you to misunderstand sorry for it.
https://www.sau.com.au/forums/topic/380680-need-help/#findComment-6078908
