g'day all, i'm just testing the interest at the moment for a potential part out, car is a massaged R32 GTR, 100% complete car with the following mods (looking at possibly selling EVERYTHING)
built RB26DETT with eagle H beam rods, CP forged pistons and possibly other part's, GT2860RS turbo's (-5's?) front mount intercooler, oil cooler, powerFC, boost controller, engine and turbo's has 14'000 KM on it, not 100% on all of the engine mods, yokohama advan RS 18*10 rims, brembo brakes, carbonetic twin palte carbon clutch, blitz BOV.
how much interested would i get in the car basic's, eg drive shaft's, box, diff's, control arm's, panels, shell, sound system ect.
body is black, in fair but not great condtion, most of interior is in poor condition.
if i get enough interest i will start pulling the car apart for part out, cheer's.
Edited by ttoks
https://www.sau.com.au/forums/topic/380739-eoi-complete-r32-gtr-part-out/
I'm interested in a complete head/wiring loom?
also the front right axle and front tail shaft.
hot33r will take the bottom end so theres the motor!:thumbsup:
  • 1 month later...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
