Hey guys,
The factory boost gauge on my Rs4-S isn't working. I've taken it to be looked at by a professional and he told me that the MAP sensor was shot (see pic below). Any advice on how I can hold of a replacement would be appreciated.
Also, in my car the climate control and triple gauge cluster are swapped around. From what I've seen, the gauges should be at the top... While the car was being looked at, I asked about swapping the gauges around so that they'd be in the correct spot. I was told that I had the wrong mounting bracket in my car, and the gauges couldn't be moved up a spot because of this. Any takes on the situation?
Edited by Marshstag
+1. I did this with mine after Scotty posted the fix originally. Has worked perfectly ever since.
You can probably just invert the din bracket; that's probably how they were moved originally.
Your car didn't roll of the factory floor with the triple gauges or the bracket is from another stag (rsv?). It would have had a double din stereo under the climate control, I had the same problem when I wanted to move my climate control to the middle and put the gauges up top.And you cant just flip the bracket over, wont work you'll have to do some modifiying to move your gauges mate.
Edited by SatchiThaStagea
The sensor is probably faulty due to dry solder joints on the plug. Here is a how to for repair if you have a soldering iron handy.
http://www.skylinesa..._1#entry4953193
Sounds good, I'll give that a go on the weekend. Can I assume that it's the same for C34s2?
What did you end up doing?
mine is in a funny order too
i also have funny extra holes drilled in it
must be a jap thing
I'm not sure if it's a Jap thing or a previous owner thing :P
I just made do with what I had and ended up with the climate up top, gauges in the middle and stereo at the bottom.
theres 2 problems with trying to move the climate control,
1: the front of the climate control is a little wider than the bracket so the bracket is cut to accomodate this and;
2: where most things are mounted from the middle (stereos, din pockets ect) the climate contol is mounted from the bottom of the side
look here for my post that shows these probs
  • 4 weeks later...
I've had a look at your post and I'm now on the hunt for correct brackets... and I've found the ones below. They appear to be different from the bracket in the pic you posted. Does anyone know if they will be appropriate?
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
