hi there guys.
i just bought a z32 ECU - with nistune board - for my RB25det ( s13 conversion ).
all works perfect - but the vtc... it's not working :(:( with stock RB25 ECU it works fine.
can't figure it out.
what could cause that problem ?? any idea's ??
cheers guys.
how do you know the vct is not working?
when revving U can easily hear it "click" - from under the hood.
when stock ECU connected it works fine - dyno all fine
with z32 nistune board plugged in - it does not click :( and it's like 100Nm loss :(:(
Have you checked for power at the solenoid up the front?
Also, you can turn VCT on at idle and it should change revs noticably. Use the nistune software to do this, its an easy test
the power should be there ( on stock ECU it is ) ; ( it's triggered by negative from ECU )
how can i turn the vct on with nistune software ?? i'm new to nistune .....
i know you say it works on the stock ecu and not on the z32 nistune board
just check you have a working NTR switch, from memory, VCT (at least on the stock ecu) wont fire in neutral, the car must be in gear (clutch in)
never had problems with that - it was always cutting in when parked revving ( by hand from under the hood ).
none of the gearbox sensors connected - speed / reverse etc.
last time i checked - it was powered - by typing "should be there" i ment - it was there like an hour ago - last time i checked ;) no worries mate - i got your point ;)
but it still doesn't work :(:(
Think pin 113 in the ecu is VTC control power, check this with a test light when rpm is above 1500.
But as the guys said above if the ecu doesnt get all the signals required (speed and neutral/clutch switch) than it wont activate the solenoid.
Because u said dont have a speedo in ur s13 u should be able to go into nistune and set the minimum speed for vtc at 0 and try it
yeah - it is pin 113 - and no - there is no negative coming out of it :(:(
i can't see the option - " minimum speed for vtc " - only MAXIMUM hmmmmm
PS. Neutral switch - if not connected - the ECU thinks it's on gear all the time right ??
Edited by kubus
i thought pin 113 is a positive?
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
