  • Replies 52
Posted Images
well this thing is crazy LOL
im running Dunlop sports tyres 295 and just spins them up need to learn throtle control abit better..
Though im getting abit of blow by into my catch can so need to sort this out been thinking of adding a secondary catch can that sits ontop of the covers then breathers going into anther can..
maybe even a return into the sump..
Wait until you track it and see if it blows oil as well.
I think I have solved the problem not with a drain to the sump but with a sump breather. I installed two 1/2 in outlets from the sump - the intention was one for a breather and the other for an oil return but in fact they are both function as breathers at the moment. Very little oil comes out (and what does could be attributed to the fact that it is well overfilled) but a fair amount of air comes out - not necessarily blow by but possibly pressure created by the crank.
ok so before you added the breather you had the catch can filling up?
also how is your pvc hooked up? & your breather setup how have you made that work?
i plumbed up the drain back to the sump but it is still filling up the catch can.. though i only have a 1 litre catch can cause of no room.. been trying to get a fabricator to make one as big as possible whith the room have.
I am currently evaluating progress and waiting for my next track day to decide on a permanent set up but I have two catch cans at present. The two breathers from the sump go into one catch can which is vented to atmos atm. The pvc hole is blocked off. The two breathers on the cam covers go to another catch can which is also vented to atmos. There is no oil going into the catch can from the cam covers now (as opposed to heaps before). There was one episode where oil went into the other catch can from the sump breathers but that could be because I overfilled it by a couple of litres (not as bad as it sounds because there is a 10mm adapter plate between the RB30 and my awd sump). I think the combination of smaller restrictors and the vents on the sump have done the trick. There is quite a bit of pressure built up in the sump and part of the theory is that this impedes the flow of oil back to the sump so it goes out the top instead.
If there is no more oil as such coming out when at the track I would be keen to fit a proper oil/air seperator or a properly baffled "catch can" and then have the catch can vented to an inlet somewhere so that the is some suction applied to the sump and also nothing going to atmosphere.
Actually its going on the dyno on Friday so this will probably be a good test as last time it also spewed out oil everywhere after a few seconds high speed running under load.
Have you got a drain from the head to the sump? Does it run to a new fitting? As an experiment try disconnecting the drain from the sump and putting it into a temporary container (to see how much if any oil comes out that way) and fitting a breather hose to the inlet/outlet in the sump and running that up to a catch can if you have a spare or just poke it into any vented or open container and see what happens. Have you got restrictors in the oil supply to the head?
yes i have the rear head drain connected though its sharing the fitting on the hot side with the turbo drain. the fitting is screwed into the block so it sits ontop of the oil in the sump.
the best way to test what you are saying would be on a dyno?
not sure of oil restrictors sizes as the motor was built before i brought the car. bit of a guessing game... dont really wanna pull the head now its running so nice.. pinch.gif
also the breathers you have coming out of your sump do the breathers sit at the bottom of the sump (under the oil) or ontop of sump (over the oil)
Edited by BMYHOE
  On 27/02/2012 at 2:13 AM, BMYHOE said:
have you heard of anyone fitting a vaccum pump to prevent this?
Yes its been done (probably Google to find examples) - over complication in my view - may as well go to dry sump!
Its not recommended to run the head drain into the turbo drain although its an engine out job to put a new drain in the sump (full explanation somewhere in this 40 page thread! http://www.skylinesa..._sk+oil+control
but yes you could try running the drain into a pot of some sort - but with no breather in the sump oil may well be pushed out of that drain - would be interesting to see.
The breathers I have are on the opposite side of the sump from the turbo drain just in front of the driveshaft and (necessarily!!) as high as possible in the sump and above the oil level.
A lot of people still don't put small enough restrictors in with a high output oil pump on an RB30. It won't be a problem on the street but will be on the dyno or track.
since i have changed the setup with the drain back most of the excess oil seems to be draining back into the sump.
though if i hold it though a few gears i'll get around 200mls out of the breather of the catch can.
its alot better then the 2 litres i lost before
have you got an oil pressure gauge? if so whats the oil pressure at ........ also have you done a compression test maybe your rings are a little bit worn prob not if your making big power but still worth a look
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
