Hi everyone can you keep an eye out for my car trailer. Especially at drift prac tomorrow night. It got stolen from dry creek area last night and I want it back. I have spend many hours building this trailer with family and I'm furious some low life has stolen it
It's dark blue. Silver hilux stockies. All led lights. Grey toolbox on front. Full tilt mechanism. Ramps slot in behind number plate flip door. Will post pics and rego ASAP. Any help please call me on 0425313447. If u find it and help me get it back. I'll shout u a carton of anything.
https://www.sau.com.au/forums/topic/380796-stolen-car-trailer-21-10-11/
Damn man thats pretty low. Sorry to hear of your misfortune, and hope you get it back easily without too much stress.
Definitely need to keep caravans, boats, trailers, jet skis (etc) chained to a post if they are in public view.
This is so f**ked. I bet they are going to be using your trailer to steal another skyline or another import. Sorry to hear about this mate, as it sounds like a lot of hours have been spent on this trailer. Will definitely keep an eye out. Goodluck mate
They went behind 12ft barbed wire gates in a security patrolled area. Cut the lock took trailer and then hung the lock up so u couldn't tell it had be cut. It was a targeted thing. Not just a left it on the street thing.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
