Hi, had enough of the auto in my R31 . .want to change it to manual and have all the parts required EXCEPT for a NEW flywheel, can anyone here recommend a place in perth to get one from? im not looking for a lightened flywheel just a standard type for street duties
thanks in advance
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/
Most Auto RB Cranks have the Manual Pilot bush also, Remove the Steel Flexplate Hub and see if the thin bush is there,If so clean it well and lube it if not you can buy the bush from any Nissan dealer. Nissan have used the same bush since the late 60s on most Nissan/Datsuns.
Edited by N I B
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6081500
thanks N I B . . . i thought i would have to go genuine but it turns out veale in Redcliffe have them so i got a new bush for 8 bucks
it will be a spare if my crank already has one!
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6081614
i will suss it out this loooong weekend but from the QUICK glance at the motor i had last night im gunna have to put the bush in. . .jonno do i use a socket/grease to install the bush?
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6082849
once you have the auto one out clean out the crank as best you can then soak the new spigot in engine oil then tap it in with a socket and hammer. make sure you use the right size socket as its very soft and distorts easily.
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6083097
either pack it with grease and find something thats a tight fit inside the auto one and bash it into the crank or if that doesnt work weld something to it (without touching the crank) and weld that to a chain or similar and give it a tug.
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6083139
when i converted my Ti, had to remove the auto bush and replace it with a manual bush.
I did mine at a mechanics workshop though, on a hoist. Feel sorry if you have to do it laying under the car.
Need to seriously work on my ti haha
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6084330
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
