C210 Carbon Guage Pod Upgrade
As the car is currently gutted and getting suspension and rust work done to it I thought I'd have a crack at modernizing the interior. I plan to go with a mix of black leather ans suede with some carbon trim pieces. May Not everyone's cup of tea but I like it.
Now getting real carbon replacement pieces was gonna be near impossible but this new 3M 1080 Carbon is damn near to real thing in terms of looks. so I pulled apart the gauses and set out to replace the brown trip with carbon. Total job time about 2.5 hours.
I was gonna change the colour of the bulbs too and swap them out with LED but seeing the orange covers on them I thought I might as well leave it
Lay over the carbon
Heat it up with a hair dryer and push down the edges to make the crease
Take a sharp knife and cup it out. Remember to pull out all the coloured plastics too as you dont want the scratch these with the knife. Take your time and be careful not the snag the plastic with the knife.
BEFORE
AFTER
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
