Engine bottom end rebuild 200kms ago - currently running in.
Time to advertise the Stagea Ive owned for over 6years.
Bought for 18k, and spent well in excess of 35k with modifications over the years. Owes me well over 50grand.
Tuned numerous times following upgrades, originally from 120kw to 140kw, to 160kw, to 180kw, to 185kw, to 190kw, to 200kw, to 205kw, to 220kw, to 235kw, to 240kw, to 250kw.
All work performed by Boostworx (Shaun Dunns); have been a loyal customer throughout.
Advertising as I'll be a University student for the next 4 or 5 years and looking for a cheap basic run around car instead of this beast.
Mods as follows:
1997 Series 1 Nissan Stagea RS V Four Station Wagon,
118,000kms, forged RB25DET engine, Attessa 4wd, Automatic,
Silky Snow Pearl, Dayz bodykit, Fresh fluid throughout. Well Maintained. 335rwhp / 249rwkw
Fully built, forged engine currently being run-in. All work by Boostworx.
Engine:
Bosch 040 fuel pump with direct battery feed at 13.8volts
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic manual electronic shift kit & auto service kit
Koyo Radiator upgrade
Greddy remote oil filter relocation kit
Fujimoto sump plug drain valve
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3” JustJap stainless steel single dump pipe system , with 3” de-cat pipe
3” cat-back exhaust system with Magnaflow mid-muffler and Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide for cold air induction
Apexi power intake pod filter, using standard snorkel air feed & under body feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Hard pipe turbo intake kit
Garrett 18psi heavy duty turbo actuator
Garrett GT3076 700177-5015 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
- 60mm diameter 84-trim GT30 turbine and 76mm diameter 7/14 bladed compressor wheel
JDM S15 Silvia 450/480cc injectors
CP forged pistons, with complete engine rebuild
ARP head stud kit
Ported, Flowed & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam camshaft set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
700177-5015 GT30R Turbo CHRA Specifications:
compressor wheel inducer size: 57.02mm
compressor wheel trim: 56mm
compressor wheel exducer size: 76mm
turbine wheel inducer size: 60mm
turbine wheel trim: 84mm
turbine wheel exducer size: 54.8mm
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear heavy-duty adjustable sway bars
Dayz adjustable engine swaybar
Whiteline front castor kit
Whiteline rear subframe pineapple alignment kit
Ox_Wheels 18x8.5” +35offset
Pirelli Pzero Corsa semi-slick 235/40/18 tyres
Brakes:
R32 rebuilt rear brake calipers and discs, braided lines
R32 rebuilt front brake caliper, CZP brake bracket, 324x30mm drilled track rotors
Cusco brake master cylinder clamp
QFM A1RM front and rear track brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Interior:
SAAS D1 Drift adjustable race seat
Flynn racing seat rail
Apexi electronic boost gauge
AEM F/IC-8 Piggyback ECU with Dell c640 latitude laptop
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 1.00 bar and 1.20 bar
Toshi ecu remap
Boostworx tuned 249rwkw
Bad Points:
Under mirror rust bubble hasnt been attended to as yet.
Under rear guards the paint has chipped since the guards were slightly rolled.
Minor scratches on the roof from some low-life.
Priced to sell at $15,000.
Southern Adelaide pickup.
My pride and joy, but need to put myself through University (Med.Science) and I feel the Stagea wont be loved as it should during my Uni years.
Comes with Dell laptop to tune the Fic/8 piggyback ecu. Also will provide all spare parts.
Picture showing current near-new 18" wheels
Previous photos
https://www.sau.com.au/forums/topic/380883-sa-1997-nissan-stagea-rs4/
Its advertised here on SAU, only. Genuine reason for sale - House still hasnt sold yet after half a year under contract, I cant afford morgage repayments & am on the absolute bones of my arse. Pretty much hit rock bottom 2 months ago, which is a good thing in all honesty as I made myself get off the medication that sent me crazy.
Heart says Im silly to "give it away", head says to be smart about it. University is my #1 priority for the next 4 or 5 years.
I'll get stuff all back from the house sale, when it eventually sells (been screwed over by the agent),and will need it all to cover living costs.
Funds will be too scarce while at Uni to run the risk of anything going wrong, even general maintenance, on the Stagea.
I really dont want to see it gone, but all my time will be focused on succeeding with the Medical Radiation Science course. For the first time I just dont see my pride & joy being in my future - however I now see a future for myself. Just need a little run around car to run errands as I'll be using public transport during the weekdays to/from Uni in the city.
Considering Ive spent well over 50k all up, including car purchase, 15k is probably letting it go too easily, but perhaps its the right option in my current circumstances. Whom ever buys it, whenever that happens, will be getting something pretty special.
Sad about it, nonetheless.
Built for Go not Show
Quite a few things missed in the 1st post listing (for example: Dazy bodykit, Twin sunroof, Momo steering wheel, etc.)
Comes with a whole load of spares.
Now also advertised on Drive.com.au
genuine sale - $15,000 firm.
didn't see that one coming! thought this would be something you'd be holding on to forever!! after everything you've been through with the car it must be hard for you to have it for sale, but looks like you know where you want to end up and how you're gonna get there so looks like it might be a step in the right direction. wicked rig, seen it in person, and deserves a free bump. good luck with the sale big fella :thumbsup:
Thanks Mike. Always said Id have ownership for a dozen to 15yrs - perhaps I still will but putting feelers out there in case someone is interested. My attitude now is "its just a car" and she deserves better than that, but all my focus is geared towards my future years at Uni and a cheap run around car will do me just fine for the next handful of years.
man both your cars are so cheap.. im in the rock bottoms of income atm but i sure do hope i can get a permanent job soon!!! sooooooooooooooooooooooo cheeeeeeeeeeeeeeeeeeeeeap..
Im sorry but probably not. Is it 2 or 4 door?
Id be after a sedan or a wagon if I was to sell the Stagea.
Probably wont sell my car at this stage, unless someone paid the $13500 (Firm) - sold the track car last night so Im in no rush to sell the stagea now.
And considering the engine is only 400kms new, with up to 300kw potential once run-in and tuned, Im possibly better off at the moment to keep the Stagea - UNLESS a deal that was fair to me was negotiated.
  • Like 1
  • 3 weeks later...
Done 900kms now, arranging the tune soon.
Had a very nice offer of a R34 gtx sedan + cash my way for a swap but honestly im just after a cheap budget run around car for errands. Happy for swap&cash but based on a basic run about vehicle. Cheers
hey mate ive got a 2002 Honda Jazz VTI-S which I could offer for trade + cash if you're looking for a run a bout. It's been my A-B car and has even been to the snow and back no worries. It's a hatchback but with the way the fuel tank was designed and the rear seats fold you can fit snowboards, couple roadbikes in the back no worries. 5.5L/100km doing highway home to work can't go wrong either!
I'm in melbourne though and currently in tassie for work until mid feb so if you haven't sold it by then keep us in mind, just wanted to see what you thought about it
I know the car, nice little vehicle. Potentially interested BUT is it an auto (cant do manual; no knees)?
Had 1000km run-in service completed yesterday with a quick tune, 230rwkw at 13psi (rwd dyno with front driveshaft out).
Builder/Tuner wants me to do another 800kms then come back for a hi-boost tune.
  • 3 weeks later...
Thanks terry, yes I think so. If no one wants it and I've still got it post-Uni I'll take it further with a nismo bodykit, full respray, larger injectors & z32 nistune ecu setup. But for now im better off with a cheap economical 4cyl runabout.
