So I'm considering trading up my S13 NA for a R32 NA, The thing is it's auto...
I'm had a 5 min look through the forums and couldn't really find what I'm after so here it goes;
Costage round abouts?
What's involved?
Would you stick a Rb20 gear box or 25 in?
Thanks, no trolls either don't really know anything about drivetrain. :P
https://www.sau.com.au/forums/topic/380889-r32-manual-conversion/
Wouldn't recommend an RB25DET box for an RB20 NA, too big, heavy and strong for the almost zero torque levels that you can throw at it. Too expensive too. An RB25DE box is essentially the same thing as an RB20DET box, just slightly different ratios. Either would be fine. Either should only be about $500.
You will also need a flywheel. If you get one with the box, so much the better. Otherwise they are cheap enough secondhand, but you could also buy a brand new lighter one for a few hundred.
Clutch - doesn't need to be much. A standard one will do the job. Cheap enough.
Gearbox crossmember and mount needed.
I think you need a different front half of tailshaft.
You will need the pedal box so you can hang the clutch pedal. You'll obviously also need the clutch master, clutch slave and some pipework. This stuff is best gotten from a wreck unless you want to make the lines up new. Make sure that you get the right slave to suit the gearbox that you buy. There are differences.
You also should get the driver's side engine bay loom from a manual. Will make it much easier to put it all together than trying to mod the auto loom.
But, I must say, that all this adds up to far more $$ than I would ever recommend that anyone spend on an NA R32. Seems like a massive waste of cash, when you can buy a manual turbo R32 for somewhat less than $10k most days of the week. Even if you do it with a turbo gearbox with the later idea of putting a turbo engine in, you need to throw so much more money at it (brakes, hubs, diff, fuel pump, intercooler and pipework, etc etc etc) that you would have been far better off just buying a turbo in the first place. I know you're not asking about turboing anything, but it's a logical path to want to follow (just not logical to do).
But, I must say, that all this adds up to far more $ than I would ever recommend that anyone spend on an NA R32. Seems like a massive waste of cash, when you can buy a manual turbo R32 for somewhat less than $10k most days of the week. Even if you do it with a turbo gearbox with the later idea of putting a turbo engine in, you need to throw so much more money at it (brakes, hubs, diff, fuel pump, intercooler and pipework, etc etc etc) that you would have been far better off just buying a turbo in the first place. I know you're not asking about turboing anything, but it's a logical path to want to follow (just not logical to do).
Okay, You gave me all the info i needed, thank you kindly. I really don't want an auto car that's all.
So basically, in the end, Unless it's my pride and joy, It's not worth converting? I think i'll give it a miss then but will find out prices, once again thanks.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
