So, this is a build out of necessity more than anything.
I bought this 94 JZZ30 as a clean daily driver with a bit of poke July last year, mostly stock with just a cat back and some silly big cannons out the back and a Boost-T thingo.
flash forward to Jan this year and a weapon of a hail storm ripped through Canberra and I ended up with a badly hail damaged car, So I still haven't had the old girl fixed yet, but hopefully by the end of the year she will be all shiny and new again.
So apart from servicing it and changing the wheels I had an interesting experience when the viscous fan exploded and took the radiator shroud out with it, luckily the radiator wasn't damaged and with Toyota wanting $500 just for the fan hub it now has a couple of thermo fans keeping it cool
I drove it around until a couple of weeks ago where I found a great deal on a HPI front mount kit, So I nabbed it and had it fitted in a couple of hours
Fitting was a breeze, with every nut/bot and bracket needed to fit straight up with no cutting, I highly recommend using the Jap brand kits for cars, and in fact this kit was cheaper than 99% of the China ebay kits.
Only down side to this kit is that the standard air box no longer fits, but HPI were kind enough to supply a pod filter and adapter with the kit (won't get that with ebay kits)
Now for the interesting bit.
Blew a turbo yesterday :( Which is a bummer because after a couple of months umming and ahhhing over what to do with the car, I had decided to keep it standard engine wise and throw a manual box up the middle and leave it at that.
The car had other ideas unfortunately
So what to do?
buy a set of unknown stockers and hope they last? Nah
High flow...Too expensive for what you get.
Big Single...YUP
But what to get?
the Short list was a Kando T67-25G which have proven themselves to make power a plenty, but long term reliability??? Its an unknown, and to me something needs to last 5 years to be classed as reliable.
A T78-33D popped up for sale on the forums here..My Original thought was it would be stupidly laggy. But the wonder of the interwebs led me to a few guys using the exact same turbo On 1JZ's and with reports of +ve pressure at around 3700rpm and full boost at 4500 on a stock 1J seemed of to me.
A Borg Warner Airwerks 83-75, Wouldve been great but with a 3 week wait on stock and me needing this car back on the road ASAP.
So I had a good thing about it, and decided that an old school style JDM Soarer would be different enough to satisfy the hipster in me, yet proven enough to not be walking into the unknown, as well as future proofing the car for the inevitable 3L high comp bottom end.
So While I'm waiting for bits and pieces including the turbo to turn up. I'm shaking my head at myself for grabbing this huge turbo, while still having the Standard ECU and injectors in the car...yes yes I know....but I'm not a silly bugger on the street and just cruise around, So I wont have results for a while about how this turbo goes on a stock 1J at full noise for a while until I sort out injectors and a Piggy Back ECU.
Anyway I'll find some more pics and through up over the next few days.
Cheers
Andrew
https://www.sau.com.au/forums/topic/380895-the-lag-meister/
  • Replies 203
So after 8-9 hours here is how it sits.
GTR owners, you have it easy!
And the damaged turbo
sucks because the rear turbo looks perfect, but there is a fair bit of ceramic dust so it would only be a matter of time before it let go as well.
Will update later today as its beer o'clock right now
Cheers
Andrew
https://www.sau.com.au/forums/topic/380895-the-lag-meister/#findComment-6076617
have to wait 6 months hey zebra. :P
saw this on import monster ( clicky ) today , i was going to post it in the wasteland whore theard but then i realized it was for a different toyota.
have you realized you called your soarer a snoarer in the title?
https://www.sau.com.au/forums/topic/380895-the-lag-meister/#findComment-6076874
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
