That's the thing about the precisions if you want low boost you can if you want big #'s turn it to 35psi. Why limit yourself with thr 6262for 4-500rpm.. On supra forum there's a good guide on how to make the stock auto live with big power.. If you stick to the same rules as the guys with built stock auto running 8's in full weight supra it should handle high 400rwhp ok.
  • Replies 203
Cheers for the info, I'll have a few drinks tonight and Sort it all out.
Just came back inside after fitting the exhaust manifold....an angle grinder was used lol
but its all fitted up :)
pics of my grinding work to come lol
Hmm crappy pic...but the only one I took today and there are not any photos on this page yet.
Used the T78 to mock up the intake pipe, had some 3/4" push lock hose laying about so removed the funky 180deg metal heater hose bend (gives me more room and looks neater (see earlier pics of said funky 180deg metal thing lol)
Painted the intake pipe with gloss black engine enamel, and went to paint the coil pack cover thing the same but, got one little spurt of paint from the can and it was empty...So now I have 1 big black spot on it..... >_< Will finish later.
Forgot to get pics of my epic angle grinder attack on the manifold so will do that tomorrow....If I remember. Going to marques in the park for some inspiration.
Nate I see you reading, come say hi (and give me your wheels lol)
Lol, should i drive up to canberra for you to help me out with the signal stalk problem?
nah, i'll sell this thing, the moment i fix something, something else goes wrong, i'm so over this. Might get into a vvti one day...
Lol, fixed the indicator issue already, i found a 10amp fuse where it was supposed to be 15amps. what a goose, that previous owner. how did it manage to survive this long however, i have no idea. the fuse that is.
car will be going on carsales, next week.
yeah 6262 with a twinscroll .84 A/R rear on it
should just touch 400rwkws with a set of drop in cams on the 1JZ at 30 or so psi and E85
even if it doesnt make 400 the area under the curve will be a lot better
hahah, was it in the absolute pain in the ass fuse box by the accelerator pedal?
I hate the one!
Everything should have been in the neat one under the bonnet
yeah, even asian sized me, i knocked my head on the steering wheel twice. you want the whole conversion kit? 2.8k its yours.
=x
nah people ask silly money for 2nd hand torsen diffs...will get a TRD 1.5way for similar $$$
will have a surge tank and 2 x 044s, ECU wise I have no idea at this stage but leaning towards the Adaptronic E1280S
will cross that bridge when I come to it I guess
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
