  • Replies 203
hahah I'm going to try and do it period mod, So it looks like it was wrapped in a bubble in 1997 or something.
So something along the lines of an old school Jap turbo kit (td06H-20g anyone :whistling: )
We shall see, what happens, it has a built A340E and a 3k(ish) stall, so next year sometime I'll drop a 5 speed in it get some big brakes on the front and get into some track work again.
Going to keep this one nice and simple (re: minimal mods) and tidy it up...and the most important thing
DRIVING THE BLOODY THING!
tl;dr? sub 300kws, brakes, drive
yeah or that.
I figure that if I keep it VERY simple I should be right lol
I wasnt planning on selling the Soarer...but this was too good to miss :thumbsup:
Also means I no longer have to keep an eye on my105 for a cheap as chups track car as I'll just use the supra
Back to the Car - I originally thought that the Twin Turbo R wasnt all the much different to the regular JZA70, I initially thought that all it got was much lees weight, recaro seats, momo wheel and Bilstein shocks.
Turns out it also has bigger anti-roll bars and stiffer springs, Now the Bilsteins are long gone (now has KYB's) No plans to change those just yet, as this car will well and truly be a case of if it aint broke don't fix it. May even save a thousand odd bucks on the brake upgrade and throw some track spec pads at it and see how it goes.
so no more soarer????
Still here being picked up just after xmas...did yours sell or are you parting it?
brake rotors and pads first, dont be one of ''those fanboys'' that think they need brembos to be fast.
brakes are pretty average standard, 300x22 with a single piston caliper
Dont fit
There is/was a kit out there that used R33 Gtst Sumitomo calipers and a 324mm rotor, was looking at pics of the kit yesterday and in all honesty it looks rubbish
Wilwood do a kit for under a grand using 330x28mm disks and their forged superlight calipers.
Not a huge fan of the cheaper wilwood calipers, so may buy the hats and get a thicker rotor and their better caliper and have bracket made to suit.
Just stumbled across this pic
I knew the 1JZ had short rods, but not this short
1JZ-gte rod and piston on the left and 2JZ-gte rod and piston on the right, 2JZ rods are shorter than RB30 rods too btw
1jz rod is 125.25mm, and look how solid the thing is! So any plans I did have of rebuilding the 1J down the track just got a whole lot cheaper :D
1J and 2J pistons also have the same pin height, so they are interchangeable but the piston crowns are slightly differernt
wow that's a short rod, the 1j rod looks alot thicker than the 2j rod too.
the piston skirt looks a little different between the two.
Edited by tweety bird
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
