  • Replies 203
what about just tacking it together and getting someone else to weld it up? worst case they can grind off your tacks after retacking it themselves - doesnt help the DIY aspect but it will be nicer finished product from your last pic :P
wait, doesn't the soarer share parts with the supra? shurley you can get the pedals from a supra and put it in your soarer.
btw this is a reply conversation in the wasteland.
edit found this clicky
Edited by tweety bird
It does, so most of the Supra stuff fits or goes close.
The main issue is the JZA80 never had the R154 5 speed, only the X chassis and 70 series Supras had the 154, which are slightly different to the the Soarer spec box (Soarers have a remote shifter)
But yeah, the pedals are a 99% bolt in
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
