  • Replies 203
:banana:
Shake Shake Shake
So anyhoo Ive had the t78 on ebay for a few days now...just to see if there is any intrest..and because it looks look bloody hard to get it all to fit in nicely...and yep...reserve has been met :D
Sooooo on the hunt for something that is maybe a bit more responsive on the 1jz....thinking maybe a PT6262...but dunno yet...will see what happens I guess
lol...well 2 hours later the turbo oil drain is fitted....sounds like a simple job yes......LOL
1JZ Soarer = same a TT 300ZX lol
had to take out a steering rack mount bolt, turn it upside down, so the bolt head faces the sky and make up a washer for it.
Looks like the oil drain kit I bought is for a front or rear sump JZ and not the mid sump engine....oh well...its in now...goes around infront of the bottom radiator hose to make sure it clears the manifold (plus its a bit long)
Also discovered the front crank seal is leaking a bit (common JZ problem) so I am covered in oil after being under the car.
Now just have to elongate the holes in the manifold flange (lol flange) which will be fun using my pissy little dremel on stainless....mind you I have ported cast iron heads using it lol
The 6262 exhaust wheel will choke before you can benefit from the high flow front wheel.. I doubt you'll be able to run 30+psi on a gt35 sized exhaust wheel.. Id go straight to the 65 rear wheel and deal with a few hundred extra lag.. What gearbox you running?
Standard Auto Trans for now.
I wasnt really concerned abooooot the 62mm rear wheel, I am more worried about the small split housing.
But how much more lag will the 6266 have? At this stage it looks like the 6262 will only be 500rpm in front of the t78
Will only be turning to 7200rpm until I can build an engine....then It will go OVER 9000! (well more like 8000 lol)
Hmm more research needed
As Lith mentioned in the precision thread plain bearings aren't known for reliability if I was going to run low boost I'd just go with something tested like a 3582.. If you have plans of building the motor I'd scarifices a small amount of lag increase and get the 65 rear then you have the option of turning it up later. If you go 6262 your limiting yourself for a few hundred rpm spool..
yeah, just found a few results of 6265s making 400+kws and reasonable response, so might be the go
MV kit I will probably get...but I am hankering for a manual box, so time will tell what i'm going to do there.
I do like corners more than drag strips these days lol.
I think I have decided on a PT6262 though, and will just wind boost into it until it stops making power...the auto will go pop before the turbo gets into its stride anyway. and 6262s have run 8s in EVO's so we shall see
+ I still have standard cams and head so a 6266 will be wasted on this engine.
will go something silly big if I build a 2J ;)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
