Item: Custom made exhuast for my R32 GTR
Tucks up nice & Tight
Made Of Stainless & Mild Steel
Few Marks etc but no leaks
Complete system from Turbos Back.
X-Force Splits Dumps (Same as HKS)
Front Pipes
X-Force High Flow Catalytic Converter
Twin Catback - includes:
Twin X-Force Resonators
Twin X-Force Cannons
Price: $950 Negotiable Need it Gone
Can deliver within 35km radius for free
Pictures:
Edited by krayzie32
https://www.sau.com.au/forums/topic/380903-custom-twin-r32-gtr-exhaust-system/
Ill measure them up and get back to you luke...
As for Noise, it had very deep idle and roared very loud when opened up...
Ill see if i can dig up an old audio clip i had...
Cant find the old sound clip cos my phone wasnt backed up & portable hdd shit itself also...
Minimum ID is 67mm
- Dumps exit
- Front Pipe Entry
- Twin Resonators
- Twin Cannons
Maximum ID is 76mm
- Front Pipe Exit
- CAT Entry
- CAT Exit
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
All good mate,
The front pipes & the rest of the exhuast is custom made to fit my R32 GTR by Performance Exhuast Northmead 3-4 years back.
Rest of the hardware such as CAT, Resonators & Cannons are X-Force items.
Im Based out of the South Coast atm & exhuast is in storage at my oldies in Sydney, I can come back up for inspections etc within a day or 2 notice...
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
