Ive got an R34 GTT that i bout a year ago that was stock besides a cat back.
Now ive done some minor mods, and its made 275 rwkw on a hub dyno, and 235 on rollers...
235 seems low for the mods ive completed.
Mods as follows:
GT3076 .63 ( exhaust housing outlet was around 2 3/4" for some reason??)
3" turbo back, custom dump, cat back fujitsubo giken exhaust
50mm synapse external gate
turbo technics MBC (soon to be profec b 2)
725cc experts injectors
bosch 044
Z32 AFM
cooling pro return cooler
NIStune ECU
Tuned by Garage 7
standard engine
standard exhaust and inlet manifold
Running 17 PSI, suffering boost drop down to around 13 which i am hoping to counteract with EBC???
Making bugger all torque too.... Cant remember figures on that though.
Anyone think that 235 rwkw on a set of rollers to low?
Any suggestions?
https://www.sau.com.au/forums/topic/380918-why-so-low/
I'm no expert by any means... Here's a comparison to what I'm running very similar
Gt 3076 .82 internal
Nismo 420cc Injectors
Spitfire coilpacks
Pod filter induction
Blitz return flow fmic
Waulbro 500hp fuel pump
3" turbo back exhaust with 100cell high flow cat
Z32 afm
Nistune ecu
Nistune boost setup running high at 18pound making 304rwk mainline dyno making 248rwk runnig low boost on 14pound from memory
Rb25neo manual r34.--otherwise mostly standard under the engine bay. Tuned using bp98
tuned by Ashley from Adelaide classic performance-hackman.
Hope that helps a bit-others will have a lot more knowledge in this area.
Edited by elir32
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074177
Overall health of the motor? Pressure drop, dependant on the size of your ic? Saturation? If you're not happy with the result these would be some factors i'd consider.
Personally I reckon thats a respectable outright power figure, it is a fair whack of boost but after all it is only a 2.5 litre.
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074353
Motors in good condition, 110 xxx with good compression across the board.
Dosnt use oil or leave any in the catch can.
Cooler is 600 x 240 x 60mm... i thought it would be sufficient?
It does get pretty hot in there lol...
Was just expecting more at the end of it.
Before i put the turbo, injectors and fuel pump in it made just above 190 with nistune on rollers...
45 rwkw was a good gain.. but for some reason i was expecting more...
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074370
When I had the turbo etc installed and tuned-the hosing to pod all had to be customized-the factory pipes were sucked flat with the force- has yours been tuned to avoid this?i found this was an issue shortly after 240-250rwk, just a thought-another mate had much the same issue doing similar, is your cat converter too restrictive?Or as matty suggested your intercooler may not be sufficient. You can get both tested..
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074376
the boost drop from 17 to 13psi is what's costing you the power.
It could be the return-flow design in itself (I wouldnt rate a return flow cooler to beyond 250kwaw); as matty suggested have the pressure drop tested between the Inlet & Outlet. You may need a 'proper' intercooler, but test first prior to spending further.
Elir32 is right with his suggestion; the intake pipe could be sucking closed if its still the standard black ribbed plastic unit.
"how to fix" here - http://www.skylinesaustralia.com/forums/topic/173016-rev210s-5min-5-intake-pipe-mod-for-your-stageaskyline/page__p__5261291__hl__%22intake+pipe%22__fromsearch__1#entry5261291
Definitely give the ProfecB spec-2 a go, a very good unit indeed. Once setup correctly could make a decent difference.
Diagnose why the boost pressure drops and you'll see a very good increase in power
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074399
elir32- not running the stock black intake, got a customized set up there, but ill check the silicon joins when i put it on the dyno next. as for the cat... wat cat.....lol :whistling:
Tangles- ill be running a pressure test on the cooler in the next few days. i knew one day the return flow would bite me in the arse lol
Thanks for all the quick replies, really is greatly appreciated
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074443
My Old setup
GT3076 0.82 Internal Wastgate
Nismo 740cc Injectors
Bosch 040
Boost T off of ebay for $30
Haltech E11v2 with Map Sensor
Tuned at Horsepower In A Box on 14-15psi made 262.4rwkw with about 400nm torque on rollers.
New Setup
Same as old except the following.
CP RB26 86.5mm Pistons
R34 RB26 Crank
Tomei 256 8.5 Cam In/Ex
Performance Springs
Head Ported
Tuned at Horsepower In A Box on 8psi made 227rwkw with 400-500nm torque on rollers.
Same return flow intercooler used in both instances, ie input/output on the same side. Measurements not too sure of, but as intercooler sizes go, it's a medium size.
As said before the boost dropping off is killing the power, but the rear housing could also be holding you back, on 17psi you should be expecting about 260-280rwkw roughly.
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6074683
Cam,
Get the boost drop issue sorted first, then begin the process of elimination from there - assuming after the boost drop is sorted it still falls sort of expectations.
You are basically getting 235rwkw @ 13psi, which is about what I'd expect from those modifications and a GT3076 with 0.63 exhaust housing, give or take 5-10rwkw. Get it to hold 17psi and it will gain quite a bit of addtional power at the top end of the rev' range.
Do you know what your external gate actuator spring is rated to, 10psi, 14psi? Running an external gate it really shouldn't struggle to hold boost, unless the turbine housing is simply too small (or the exhaust) and is choking it up - I doubt it.
A few years ago my 33 produced ~270rwkw at about 17-18psi. However, winding the boost down (or switching the EBC off and running off the aftermarket actuator ~13-14psi up top) it made 240ish.
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6083615
whatsisname- hey mate, the spring in the wastegate is around 13- 14 psi
conveniently, the same guys that tuned my car tuned an r33 with the same cooler, turbo, wastegate and EBC- pretty much a carbon copy lol.
and would u believe it had a similar outcome with the boost drop issue.
As far as my tuner believs, the wastgate is the weak point, and we are going to try a heavier spring and a few other little tricks the the makers of the gate have
suggested.
If this fails, ill be getting a Tial :thumbsup:
Out of curiosity, what size outlet did the exhaust housing have on your 3076?
The one i purchased was brand new, from a third party who has the turbo send directly from garrett, but the out let on mine was smaller than 3", which i thought was standard??
Thanks heaps for the reply :action-smiley-069:
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6084756
ok so anyone that was wondering, i installed a profec b 2, with no change in result.
Then i put a stiffer spring in the wastegate, and now with out a retune, the car makes 250 rwkw on rollers on 18 PSI with a drop to 16.5 PSI.
Im hoping with a slightly stiffer spring, the drop will be completely gone, and then a retune should see a bit more power.
So to all considering purchasing a 50mm synapse wastegate, go straight for a 120P spring.
Cheers all
https://www.sau.com.au/forums/topic/380918-why-so-low/#findComment-6105754
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
