Do you have the fronts rolled too? Do you run the front guard liners?
I believe the fronts were rolled before it arrived in Australia. There is part of the guard liner cut out or it's scrubbed it at another date... I won't be lowering the front much more than it was just the rear.
  • Replies 172
Posted Images
My car finally got set up suspension wise.... Thanks to Ken at Accurate suspension it handles like the Go Kart it should now!
Final steps is to get the paint corrected before the photoshoot.
  • 4 weeks later...
The GTR was dropped off to get it's paint correction done Yesterday. It's 96% done but these are some progress shots of final... since especially my headlights were yellowed... here are the pics :) The photo shoot is this weekend, so of course you will see the final results when I get the pics :)
  • 4 weeks later...
So I thought I would update my thread with the new pics I got by a mate of mine. Ben from Ben Birch Photography.
And if you haven't seen it check out the video we made with Mile High Films
Edited by EAT26
So I have finally got around to ordering more parts for the GTR.
1. Kulig Engineering Crank Trigger.
2. Just Jap Catch can, I am going to modify it with weld on -12 fittings
3. Twin turbo badge replacement.
I have only got to now order my custom Grind VCT cams to finish my VCT get it retuned.
I am also going to ask my tuner if I will require doing LS2 coils, not sure if I will though.
Another day... Another Car Part....
This is the Crank trigger sensor for my set up.... bring on more power :) Going to get it installed, then a couple more hours on the dyno... Then I will finish my VCT for more response.
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
