when you don't reply it disturbs me more =[
Sorry Baby....
On another note ordered the following.
And My builder ordered my oil pump on my behalf.
still waiting on my cam baffles but it'll get here should be soon :) build is coming together slowly but surely.
Dropped engine covers, and my greddy lip off the other day :).
  • Replies 172
Posted Images
I havent been on here much lately to see this thread.
Just caught wind of this. Have not heard anything about these failed pumps (which I normally would being an Aussie manufacturer) and if this is so I would be keen to hear about it. Can you enlighten me?
. In saying that we have only have two broken pumps out of the many 100's of units that we have sold internationally. Both these pumps had failed inner gears but were both due to the same reason which was from the pumps being installed onto used later model RB26 cranks that had the leading edge of the drive flats rounded which in turn enable the crank to try and turn within the inner gear. Obviously no matter how strong you manufacture a gear it is still a mechanical part that can fail given the correct environment to do so[/size]]
Yes, those highlighted points are taking it a little out of context to the full information, but it is still a failure.
Where did this come from? You should check your sent emails for that exact quote Andrew, because It came from your email.
Regards
Andrew McIntosh
Sales Manager
Nitto Performance Engineering
Now while I have you, you have a PM.
Chris.
Edited by Force Fed
I am leaning more towards a HKS oil pump mainly because according to HKS Australia they are the ONLY oil pump that is 100% made in Japan...
:domokun:
http://www.reimax.co.jp/
Edited by Force Fed
Hi Chris,
I'm glad you have an engine builder and are not one yourself. It seems that you don't quite understand basic mechanical properties which is fine but maybe next time you might think a bit further before posting up your ill informed wisdom.
Let me run through it - When you have a loaded gear that effectively driven inside by something that is larger than it (current twin flat RB inner gear design) then no matter how strong the gear is, it is still prone to failure if the drive is allowed to become a larger diameter than the ID hole in the gear. It does not matter if the gear is made from unobtainium and treated in kryptonite, it is still physically impossible for the gear to withstand the pressures being placed on it. It WILL still fail when the 2 materials are of similar nature in composition. IE: solid metal drive inside metal gear.
The "documented failures" you refer were not because of the product quality, they were a result of incorrect installation. Just the same as you can't blame a failed piston that has seen too much pre ignition on the manufacturer when it was the tuners issue that he could not tune properly (or other factors that are out of the piston manufactures scope that could cause the issue). A failure is not just a failure as you so professionally put it.
Nitto goes to a lot more expense than other manufactures to make these gears as strong as possible in both materials and processes used. This is fact. Have you tried emailing or calling HKS, Reimax, JUN, Greddy etc about their pumps asking where they are made, how they are made and about their failures? I would guess not and would also guess that you would not even get a reply. I'm not talking about a middleman wholesaler either that will tell you what you want to hear.
It is unfortunate that manufactures face this kind of flawed information being plastered over forums these days especially when it is information that has been directly supplied and obviously misunderstood by those that have recieved it due to not really understanding what they are reading. This is why you do not see many manufactures being actively involved in forums. Too many users trying to big note themselves to the wider community as gurus when their profession is something totally unrelated and their knowledge of what they are talking about is not up to scratch. It is a real shame. This by the way does not reflect the majority of forum users.
I reiterate once again - Nitto has not had any feedback on damaged gears in any way due to the product quality. ONLY due to ill fitment which was accepted by the installers in question. The "documented failuers" were documented by us and were not due to our product. Get it right next time before you suggest toward an issue being present that is not.
I reiterate my own point
I am aware of the mechanical issue with the collar not mating to the oil pump drive correctly.
I didnt blame NITTO directly for the failure, I mentioned that there had been TWO failures in relation to the pumps.
Yes, your information is from you directly, Why do you think I emailed you about the oil pumps you have in testing currently that use a different style of pump drive.
What issue did I mention was present? NONE, I brought up the fact, that you YOURSELF had told me of these 2 known failures, which is also good that a manufacturer can speak of them openly.
Check your pm's
Edited by Force Fed
As of today...
My engine builder has....
My Jun oil pump(Last 1 available in Japan, had to directly talk to JUN themselves.)
Tomei Sump Baffle
Hi Octane Cam baffles.
Let the fun begin :)
  • 4 weeks later...
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
