Hey guys,
driving home a couple of hours ago, stopped at the lights, my 4wd and ABS lights come on and steering felt abit funny ( prob because of awd not running).
got it home and took this vid ->
first 3 seconds is fuel pump priming, but after that there is this funky noise coming from the abs module, I ran over there to check and could feel the vibrations in it.
I have never ever seen anything leaking from the unit in the 5 years I have owned the car.
I have multiple questions:
1. does the unit just need to be bled/ simple fix?
2. if I need to replace it, is it an easy job? any complications?
3. can I use a 33 s2 unit in a s1?
4. what fluid does it take and how much?
5. Is it safe to drive the car in this state? Ie if I cannot fix this by monday I need to drive to work...
Thanks heaps guys.
Adam
from the research I have done, I believe I have answered some of my own questions for other people's reference:
1. Unit cannot be bled, the normal brake system is what gets bled
2. not sure yet
3. I don't think a s2 will work in a s1 as a s2 has 2 lines that go to the top of the unit and a s1 has 2 bolts on the top instead, those extra 2 lines are attached to the side of s1.
4. fluid comes from brake master cylinder, normal dot3/4 castrol super etc...
5. I noticed especially in reverse that the brakes felt like they were stuck on, I took out the 2 relays in the black box and I still have the abs and 4wd lights on as I don't have abs now, but atleast I can drive to work tomorrow and use the car until I locate a replacement.
I will do a full brake bled and put in new fluid to hopefully see if it fixes it, but I think the unit has probably had it.
anything else I should know?
Try and get a workshop manual.
It will have proper bleeding instructions.
The r32 units can be bled, but by the sounds of it, I think the unit has seen better days.
Good luck with it all.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
