The bonnet of my car is made of carbon fibre, and the previous owner sprayed it the same colour as the car.
There are some sections though were the paint is flaking/peeling, and some where it wont lift off at all.
I was originally going to just respray it, but though id be different and go with the naked look.
So, is there a way to remove the paint and primer from the clear/gel coat underneath without damaging it?
Ive heard soda blasting could be an option, because its not as harsh as sand blasting?
Or is the only way to do this, to go down to bunnings and grab a crap load of sandpaper and whip out the electric sander?
Im just looking for the easiest method here. And also the quickest if there is one
cheers
https://www.sau.com.au/forums/topic/380941-remove-the-paint-from-carbon-fibre/
From my experience there is no easy solution to this. Rubbing back is probably the preferred option as you can control the pressure very easily. This is normally quite easy for an experienced body shop, just like re-clearing any gel coat that has started to bubble or degrade from UV exposure.
If the parts where the paint is starting to come off are only in certain sections, I would maybe look at only uncovering part of the paint so that you have sections of carbon coming through the paint.
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
