is the transmission hardware in 2011 and earlier cars identical? Would LC4 damage the earlier cars ? Lastly Martin, which gearbox program is better? the AP or the Nissan LC4?
Thanks
Yes, we have been doing this for a few months now. Nissan cant do it with the Consult to the best of my knowledge.
Speedah on here has 2011 LC4 in his 2010 ADM GTR :)
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6074653
+1 dead keen to know if "LC4" is simply software or are the internals upgraded as well.
Thanks
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6075390
How does Nissan warranty the LC4 at 4000rpm launch but not the previous programs?
software only
4000rpm launch is right at the limit of what the stock tyres + stock power can translate to forward momentum
if your car is mod'd, id opt for a lower launch rpm
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6077519
as long as you use LC with VDC-R you're fine
my 2010 activates LC with VDC-R
this was discussed here a while ago at length, and pretty sure the 2009 ADM guys said they can activate LC with VDC-R too
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6077563
software only
When I asked Mizuno-san, face to face, at Philip Island 2011 GT-R launch, if Nissan would honour its much publicised promise to offer upgrades to 2009/2010 cars to 2011spec LC4 ,
his answer was: "not possible, veeery sorry, different internals"
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6079130
Transmission hardware for the 2011 GR6 is identical to the 2009/2010 cars.
There are some small ancillary differences such as slightly different oil pan design, one fluid magnet rather than two etc. Nothing you would consider a design change. Take that from someone that has stripped both transmissions :)
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6079508
I honestly fail to see the attraction of a 4k clutch dump
I cant get full traction at 3k, and this was when I was running Cobb and midpipe only
It is actually quite a smooth event in the MY11 at 4,000rpm. I imagine this is why it is now warranted at this higher engine speed.
I had the opportunity to do a few launches side-by-side with with MY09/10s recently and the LC4 program is far superior in that initial phase of a launch.
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6079736
i can understand that
but what happens when you start putting more power through the driveline
isn't 4k a bit excessive for the amount of grip available? and even if it did hook up, that's alot of energy going through the diffs
i come from semi-manual boxes where LC's put alot of stress on the drivetrain, so LC is not something i go out and play with
perhaps Martin who has rebuilt r35 box's can shed some light on what kind of damage over use of the LC causes, or whether the software is so good it can minimise the damage
Edited by domino_z
https://www.sau.com.au/forums/topic/380950-lc4-flash/#findComment-6079783
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
