unfortunatley not Andrew lol
that really needs to be laser cut, then CNC milled from the look of it - though im tempted to get the file for the 1uz to T56 file and see what their machining options are, i do have contacts for all this stuff now.
even if the laser cutters did the main work then etched the surface for the milling part you could spend some time doing it manually on a mill.
  • Replies 87
The turbo has bolts atm, would like to keep that if possible....as for the dimensions to the outside...it doesn't really matter, but I would like the center hole for the pipe to suit 3" mild steel pipe rather than 81mm
Chris, go to 10mm plate is what i've been advised by all the exhaust guys.
They see warping issues after use with 5/6mm stuff.
As for gearbox adapters, why the T56? It's a clunky as f**k gearbox. If I could have easily, I would have avoided using it altogether with my LS1 and stuck with the 5Speed.
If you've got a Toyota engine, get the V160 Box.
just did some measuring on matt's old dump pipe (same flange) it is 12mm from the centre hole to the edge and 10mm bolt holes.
Did notice though that his piping is 76mm OD...so not sure what to do there as I think 81mm will be too loose?
V160 = $4500-5000 2nd hand
T56 $1500 2nd hand
Chris
If I ever feel rich...would you be able to do one of these?
http://www.ebay.com....=item2eaded1639
i bought the 1uz one yesterday - turns out its 3 pieces for the 1uz and they recommend steel - so i'll be cutting it out next week :P
lucky we have some 12mm plate lying around :D
yeah exactly
hardest part is going to be welding the pieces together without the 12mm plate warping - might have to bolt it up to the bell housing and weld it bolted up and low heat as its under compression so doesnt have to be a strong weld.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
